Speedometer cable problems - Kawasaki Vulcan 750 Forum : Kawasaki VN750 Forums
post #1 of 2 (permalink) Old 05-07-2008, 09:22 PM Thread Starter
I bought a new speedometer cable because my speedomer was not working. The end that attached by the front tire does not quite fit. The wire cable inside the casing stickes out too far and it will not allow me to screw the end on. Any ideas?
Maureen64 is offline
post #2 of 2 (permalink) Old 05-07-2008, 10:00 PM
Chaos's Avatar
From a speedometer cable replacement years ago and on a different vehicle, I recall I had to give that wire cable inside a little twist to get it to seat down into whatever socket it fits into down there. It wouldn't just go in without a quarter turn or so, but after the small twist things just all slid together nicely.
Good luck!
Mike
2005 Vulcan - bought used August 2007
Memphis Shades Classic Deuce Windscreen
Willie and Max Saddlebags
Kaw saddlebag bracket set and taillight relocation
Kaw Rear Rack and extended backrest
Lubed Splines
Toolbox Hinge Repair
Interstate AGM Battery
Bulldog's R/R Relocation Kit
TOC Manual Cam Chain Tensioners
19,000 miles and counting...
Chaos is offline
