brake light problem - Kawasaki Vulcan 750 Forum : Kawasaki VN750 Forums
post #1 of 23 (permalink) Old 03-06-2015, 02:47 PM Thread Starter
brake light problem
Well got the bike had to replace. The r/r and it doesn't over charge anymore but I need some advice on what's up with the tailight. I took it apart and it melted he inside of it partly because it's a aftermarket skull light and he cut behind the clips and I don't what wires are what but both deployments were lit anyone know why? The turn signals work but the brake llight won't come out if you press the brakes. trying to get it working to ride it'll be warm sooner than later. Thanks for the help
Joes92vn750 is offline
post #2 of 23 (permalink) Old 03-06-2015, 03:07 PM
GloryRider's Avatar
Have you checked the fuse?
GloryRider
Atlanta, GA
Current Ride: 1995 Vulcan 88 (1500A9)
Purchased Dec. 2014
approx. 6,800 miles
Previous Bike: 2000 VN750 "Glory"
With homemade stator
Details on stator build here
"Four wheels move the body. Two wheels move the soul"
"You live more in 5 minutes on a bike like this going flat out than some people live in their lifetime." - Burt Munro
GloryRider is offline
post #3 of 23 (permalink) Old 03-06-2015, 03:11 PM
If the tail light is aftermarket, it would help to show a photo. there should be 3 wires for each bulb and 2 elements in each bulb.
are you sure the bulbs installed are dual filament bulbs?
post #4 of 23 (permalink) Old 03-06-2015, 04:05 PM Thread Starter
All of the fuses are good. Relay maybe?
post #5 of 23 (permalink) Old 03-06-2015, 05:01 PM
JM2001's Avatar
Is the spring attached to the brake light switch under the brake pedal?
JM2001
" Loud Pipes Risk Rights "
2001 Vulcan 750
marbled
TOC upgrade on ACCT
rectifier relocated
iridiums
decals removed
upgraded mirrors
Pic up coil mod done
degoated
All LED lighting
Upgraded Mosfet rectifier
JM2001 is offline
post #6 of 23 (permalink) Old 03-06-2015, 08:06 PM Thread Starter
Yeah both springs and I the one is loose but it still works.sorry I'm on phone and everytime I try to add any pics it kicks me off the message I'll keep trying too send them tho
post #7 of 23 (permalink) Old 03-07-2015, 07:44 AM
something like this?
http://www.ebay.com/itm/Chrome-Motor...c487ba&vxp=mtr
post #8 of 23 (permalink) Old 03-07-2015, 07:47 AM
if so i would recommend that you take it off place it ever so gently on the ground and run it over with a truck
reason being is that i just installed one of those for a friend of mine and it has no visibility at all and no one will see your tail light at night which could get you hurt
post #9 of 23 (permalink) Old 03-07-2015, 11:42 AM
The switch is adjustable to take up the slack in the spring .try taking the spring off the pedal side,leaving it on the spring side.pull on the spring and see if the taillight comes on.if you want to be able to post pics from your phone get the motorcycle.com app and install on your phone
post #10 of 23 (permalink) Old 03-07-2015, 01:03 PM Thread Starter
That's it but mine is black and two mini skulls for the turn signals, Its pretty melted because he drove the bike with both feliments on so who's how he rode with the brake light on constantly so I haven't rode it wanted to get it fixed first because I live central Illinois and people are blind for bike and I'm not trying to get rear ended because they didn't "see" the hand signal, but to all keeping with me here it invaluable information and as far as the little peg on the brake I manually moved it and it didn't deactivate the brake filament. I'm also in the process on getting the app so I can upload some pictures
