output of headlights - Kawasaki Vulcan 750 Forum : Kawasaki VN750 Forums
post #1 of 6 (permalink) Old 05-04-2008, 06:36 PM Thread Starter
in my kawy book it said that my headlight uses 55/60 watts. does that mean that the low beam uses 55 and the high beam uses an extra 60 watts, for a total of 115 watts ?? or low beam uses 55 watts the high beam uses another 5 watts, for a total of 60 watts
mikewebb is offline
post #2 of 6 (permalink) Old 05-04-2008, 06:39 PM
HAWK
Ccspinner's Avatar
55 for low beam, and 60 for high.
Not added together.
There is 2 filiments in the bulb, it does not use both, just one of the other.
Chad Falstad "Hawk"
Vroc #17649
2011 HD Ultra Classic "angel"
Ccspinner is offline
post #3 of 6 (permalink) Old 05-04-2008, 06:56 PM Thread Starter
k thanks, in arkansas headlights are not required during daytime driving. i'm thinking about adding a switch to the headlight so i can turn it off, i would like to have the extra power to use for an electric vest.
mikewebb is offline
post #4 of 6 (permalink) Old 05-04-2008, 09:44 PM
That would be nice, but please remember, people in cars have a bad enough time seeing us on a bike even with a headlight.
If you do go this route, I'd suggest atleat some kind of low powered driving lights.
LED's are a good idea.
That I've heard of, we've had very few of our members involved in accidents (there have been several, but luckily they are still with us).
post #5 of 6 (permalink) Old 05-09-2008, 01:09 AM
I agree with Hyper
post #6 of 6 (permalink) Old 05-26-2008, 05:24 PM Thread Starter
guess i'm asking for a reconfirm on the lights. i have a lighting problem, the Light indictor is coming on when i go to high beam. the light is fine. i think the problem is in the "reserve lighting device". i have 2 volt meters. both black leads are connected to the black/yellow wire (ground). one volt meters red lead is connected to the red/yellow wire. the other volt meters red lead is connected to the red/black wire. when i start the bike with the low beams on the volt meter connected to the red/yellow wire goes to 12 volts, the other voltmeter stays at 0 volts. when i go to high beam the volt meter connected to the red/black wire goes to 12 volts BUT the first volt meter connected to the red/yellow wire is also staying at 12 volts. what i am seeing here is that both filaments are being used at the same time. i think that is incorrect but i would like to ask again because i know i have a problem here on this side.
so to repeat:
low beam uses 55 watts.
high beam uses 60 watts.
both beams are never on at the same time (and using 115 watts).
mikewebb is offline
