Diehard MF battery - Kawasaki Vulcan 750 Forum : Kawasaki VN750 Forums
post #1 of 12 (permalink) Old 05-02-2008, 07:45 PM Thread Starter
Post Diehard MF battery
So I got my new Diehard MF battery and installed it last night. I ordered the Diehard gold powersport 14AHL-BS. Filled and charged the battery & put it in the bike. Well, its about 1/2" taller than what will work with the hold down. I didn't think to set the new battery and the old battery next to each other to compare. A couple cableties did the trick to keep it in place for now and I added some wire loom to the harness next to the negative terminal. Anybody else experience this? Did I screwup on the order? Is there a better solution to the hold down strap?
Thanks,
bpeer is offline
post #2 of 12 (permalink) Old 05-02-2008, 07:50 PM
93VN750's Avatar
Don't know the specifics of that battery, is it possible that something fell under the battery when installing it?
Perhaps the mat folded over?
Check for the obvious.
Jon
vn750.com Member # 828
Rick's Stator and R/R
MF AGM Battery
Degoated
Shaved & Jetted
Iridium's
MAC Tapered Staggered Pipes
Battery/Temp/Clock Gauge
Stainless Steel Brake Lines
Dunlop D-404's
93VN750 is offline
post #3 of 12 (permalink) Old 05-02-2008, 08:47 PM
liljd's Avatar
I have the same battery and it is the same. I don't have the strap on mine, just put it in and replaced the seat and off I go. I thought the same thing but I thought the seat wouldn't go back on but it does just fine.
James
1985 vn700 (T'Plana)
Gremlin bell
HD-O shield
saddlebagged
custom made supports
tool bag
extended backrest
Protac backrest
Highway pegs
custom mirrors
custom grips
V&H cruisers
lever covers
DieHard AGM
Kuryakin battery gauge
and LED taillights
marbled
____________________
VROC #27169
Tn VROC #134
www.youtube.com/thetrueliljd
liljd is offline
post #4 of 12 (permalink) Old 05-02-2008, 09:19 PM
sunpa's Avatar
I bought the Sears Diehard AGM battery a year ago - same height problem. Here is a quote from my post last April:
"The new battery is about 5/16 inch taller than the original on my '04 VN750 so I had to fashion a wire "clip" and use a longer screw (about 1-1/4") on the ends of the battery hold down bracket to accomodate the increased height."
I also used some rubber cement and rubber spacers for a secure fit between the holddown bracket and the battery.
I've had no problems with the battery. I pulled it out of the bike for the winter in Dec and after 4 months it still had 12.8 V. (I checked it every couple of weeks.) I gave it a trickle charge overnight to "top it off" and installed it in early April. The bike fired right up with less than 2 sec of cranking.
- Safety First
Paul
'04 VN750
'75 CB360T
'08 Concours 14
sunpa is offline
post #5 of 12 (permalink) Old 05-02-2008, 09:41 PM
Sentinel's Avatar
I've got the same battery with the same problem. All I did was reinstall the retention strap without hooking it in on the front: basicly it's just bolted down. Not as effective as the proper method, but it works nonetheless.
For Sale: 2005 VN750, Ebony/Metallic Phantom Silver
V-Force Windshield, F&S Engine Guard w/ highway pegs
DieHard MF battery
Throttle Rocker II, both hands
Chrome trim on tank, fenders and windshield
Saddlemen Highwayman Jumbo Straight saddlebags
ProTac Driver's Backrest
Sentinel is offline
post #6 of 12 (permalink) Old 05-03-2008, 09:25 AM
My Die Hard battery had a piece of plastic on the bottom. I first thought it was part of the battery. It was not, I just pried it off and my battery fit perfectly.
Dunsel is offline
post #7 of 12 (permalink) Old 05-06-2008, 12:59 PM
What he said. Picked up this battery over the weekend, had the same height issues, until I realized it was a removable piece of plastic.
Better question for those who have this battery, what size screws/bolts do you use with this battery? I have to do a fair bit of fiddling with it since I can't charge in my parking lot.
http://www.scurvysvarog.com/vn750/
'86 vn750 since 7 May '07
Falls Church, VA
svarog is offline
post #8 of 12 (permalink) Old 05-09-2008, 05:06 PM Thread Starter
I fianally got around to checking this out last night and, yes, there is a plastic spacer with doublestick tape holding it on the bottom of the battery. Took that off and it fits perfectly. Now, where did I put that hold down strap?
bpeer is offline
post #9 of 12 (permalink) Old 08-17-2008, 01:11 AM
PoggiPj's Avatar
Send a message via AIM to PoggiPj
Thanks for this post. Now mine fits perfectly as well.
Regards,
Pete in Gaithersburg, MD
1996, 6,000 miles
Relocated R/R, Corbin seat, Plexifairing III, Sunpro Voltmeter, Sears MF.
Xelement X840 Saddlebags
PoggiPj is offline
post #10 of 12 (permalink) Old 08-17-2008, 06:37 PM
Sky Rider's Avatar
The Wal Mart MF battery has the same issue. Probably made by the same manufacturer.
Jim W
93 VN 750 "Ursula"
Moved R/R 08Sep06
R/R rewire 17Feb07
New R/R, Installed 14Jun08
New Stator installed 10 Jun08
21480 Miles
VROC #8542
Sky Rider is offline
