R/R relocate ??? - Kawasaki Vulcan 750 Forum : Kawasaki VN750 Forums
post #1 of 5 (permalink) Old 04-28-2008, 05:15 PM Thread Starter
Question R/R relocate ???
Hi all,
This would be my first real post. I've lurked for a few months but now hope to get an answer to this question.
My battery died so, I ordered a MF from Sears (mail order). Nobody around here carries one so I wait. In the mean time I'm reading about the R/R relocate and think that since the battery is out already why not pull out the R/R and do the relocate? So, Saturday I get it out where I can look at it. The nylon connector the wires are all mounted in is about 1/2 eaten by past acid spills. the white (battery) wire was just intact by a few strands of wire which broke while I was working the connector loose. So, first I thought I could remove the quick disconnect from the connector and solder the wire back on to it and put it back in the connector. Well, the quick disconnect has been hot and melted into the plastic connector. I can't remove it intact so, my question...
Is there a known source for a new nylon connector housing for the R/R connection? It would be a much better job if I put a new nylon connector on the harness.
Thanks,
Brad
bpeer is offline
post #2 of 5 (permalink) Old 04-28-2008, 06:56 PM
I'm new too, only a few days, maybe a dumb question but what is a R/R?
After reading about that a maintenance free battery cures the hot-start problem. I'm thinking about yanking my old battery out too.
GDouglas is offline
post #3 of 5 (permalink) Old 04-28-2008, 07:09 PM
On His Lady Vulcan
wkrizan's Avatar
Regulator/Rectifier, part of the charging system
Pictures of the "Ladies"
wkrizan is offline
post #4 of 5 (permalink) Old 04-28-2008, 07:22 PM
Some here have just soldered the wires to the R/R. Which is a better contact than any connector would be.
Others have just used individual spade connectors.
I believe there was a one piece unit from some older car that was a direct replacement, but off hand I don't remember what it was.
post #5 of 5 (permalink) Old 04-30-2008, 08:33 PM
darrelc5's Avatar
I recommend replacing all affected wires and replacing the connector with a new unit.
Eastern Beaver has the connector inserts:
http://easternbeaver.com/Main/Produc...en_barrel.html
Also, I have gotten two of the six-pin female connector bodies and extra inserts from RM Stator in Canada and confirmed with them that they will sell them to the public. I called Rick at Rick's Motorsport Electrics and he has them and will sell them. Give either a call.
Darrel
'03 Vulcan 750 (90k miles)
-Corbin Seat
-V-Force Windshield
-LeatherLyke Touring Bags
-Chrome Luggage Rack
-Headlight Modulator
-Brakelight Flasher
-MF Battery
-Heads-Up Voltage Monitor
-Replaced Stator (9,000 and 16,000 mi.)
-Oil-cooled Stator Mod (photos)
-Replaced and Relocated R/R
-Greased rear splines
-Fused Stator (photos)
-Metzeler ME880 Marathon 170/80-15 (Rear), 110/90-19 (Front)
-TOC MCCTs installed
-Headlight Relays
SOLD - 2013
darrelc5 is offline
