Where I can get this ignition switch part? - Kawasaki Vulcan 750 Forum : Kawasaki VN750 Forums
post #1 of 10 (permalink) Old 01-18-2015, 02:15 PM Thread Starter
Possibly online, or do I need to take it to a local shop?
sciomancy6 is offline
post #2 of 10 (permalink) Old 01-18-2015, 02:27 PM
JM2001's Avatar
You could try here
http://www.kawasakipartsnation.com/o...cks-reflectors
JM2001
" Loud Pipes Risk Rights "
2001 Vulcan 750
marbled
TOC upgrade on ACCT
rectifier relocated
iridiums
decals removed
upgraded mirrors
Pic up coil mod done
degoated
All LED lighting
Upgraded Mosfet rectifier
JM2001 is offline
post #3 of 10 (permalink) Old 01-18-2015, 02:40 PM Thread Starter
Thanks. I took the bike out yesterday to practice on slow speed maneuvers. Well I get back home, shut her off, and realized the headlight was still on, the neutral light was still on. The key was not in the ignition. Suddenly my fiance noticed something smoking. Everything shuts off finally. But now nothing will come on. I narrowed it down to the attached photo. I believe its the brown/white wire that got over heated and burnt out.
post #4 of 10 (permalink) Old 01-19-2015, 10:45 AM
emtdon's Avatar
post in the sell swap forum someone may have one.
2003 kaw vn 750 pushing 40,000 miles.
tp stator
dampers
coil relay mod
other stuff not listed
mustang seat
motorcycle repair at a stealership 1 million bucks, repairs with the help of the Vulcan750 forum priceless.
emtdon is offline
post #5 of 10 (permalink) Old 01-19-2015, 08:42 PM Thread Starter
I ended up finding and ordering a new ignition switch part for $95 bucks. So now the long wait till it comes in.
post #6 of 10 (permalink) Old 01-19-2015, 09:42 PM
Sorry to hear you spent $95 on that. I had to replace the switch assembly a few months back and I have an extra as I didn't need that part. In fact I now a whole bike that can be used for parts. Head gasket is leaking and I don't really have the experience to fix it myself. Went and bought a sportster. So if you need anything else, let me know.
nicked is offline
post #7 of 10 (permalink) Old 01-19-2015, 10:09 PM
2000 VN 750 Senior Member
Always check here first for parts unless you are totally against used. There are always several members with parts bikes willing to sell a few items to put some coins in their pocket. If you knew it was a particular wire within the bundle you might have been able to just replace that wire on your own for a lot less than $95. Find out what caused the wire to cook before you destroy another complete mini harness section by just replacing it. Good luck.
Tom
Vulcan 2000
4507 miles
Vulcan2000 is offline
post #8 of 10 (permalink) Old 01-22-2015, 01:15 AM
Verify which wire burned, and find out why. The only reason for a wire to overheat and burn is high resistance (a short circuit) The problem is not likely in that harness, but in the ignition switch or whatever the other end connects to.
2006 Sportster 1200 Low
2004 Honda Rebel 250
1979 Vespa P200E
2002 Vulcan 750 parts bike
1994 Yamaha XT225 parts bike
VN750Rider/Jerry is offline
post #9 of 10 (permalink) Old 01-23-2015, 09:19 PM Thread Starter
Update: thanks for all the help guys. Next time I'll be sure to contact on here. This particular time I just said screw, I want it fixed asap. I ended up getting the entire ignition assembly in today. There really was no hard work involved to connect everything. It did come with a new set of keys. Down side, if there is one, is the gas cap and helmet lock will still require the original key. So I'll have to have two different sets of keys. I'll live it. But I turned her on and it worked like new. Ready for the warm weekend!
post #10 of 10 (permalink) Old 01-24-2015, 09:12 AM
As for the key problem, why not rekey everything the same by checking that topic here using the search option at the top of the page. Several members have done it and now only need to carry one key that fits ignition, gas cap, helmet locks and rear tool box. It is a do it yourself option.
Tom
Vulcan 2000
4507 miles
