MOSFET VS SERIES - Kawasaki Vulcan 750 Forum : Kawasaki VN750 Forums
post #1 of 52 (permalink) Old 01-14-2015, 12:50 AM Thread Starter
MOSFET VS SERIES
I am researching series regulators and they seem the be the best replacement for the VN750. Even the mosfet is a shunt type, so the stator is producing full output 100% of the time. So the heat built up in the stator is not changed from the installation of a mosfet. The Series type controls the output so the stator only generates what is needed. I have not found a reliable source to learn the wattage of a stock stator. The only number I found is that it produces 20A. Amazon has 22A series regs for $90, 32A for $112. Mosfet shunt type is $40 + shipping. Seems for a extra $40 the series would make the stator last much longer only producing the heat (power) as required by electrical system. Seems the extra $40 for only replacing it every 60K miles would be worth it.
smltownr is offline
post #2 of 52 (permalink) Old 01-14-2015, 08:46 AM
Explain to me how the stator gets "turned off" by the R/R. Isn't it always producing volts as long as it's spinning?
post #3 of 52 (permalink) Old 01-14-2015, 08:55 AM
Crowley
crowley1027's Avatar
It doesn't get shut off. The r/r communicates with the stator differently... It probably always takes 14v and puts it in the battery, and does magic to get rid of excess energy
crowley1027 is offline
post #4 of 52 (permalink) Old 01-14-2015, 09:57 AM
Yup,as long as the stator is spinning it is producing energy. We all know the rectifiers job is to deliver the energy to the battery / electrical system as needed and to discard what's not needed. Both style rectifiers do the same job in different ways. Everything I have read the MOSFET runs cooler and from experience I know it runs cooler and more efficient than the old style.
post #5 of 52 (permalink) Old 01-14-2015, 11:11 AM
Crowley
The question becomes - where does the extra electricity go?
post #6 of 52 (permalink) Old 01-14-2015, 11:55 AM
Nardia
post #7 of 52 (permalink) Old 01-14-2015, 12:36 PM
Crowley
Narnia?
post #8 of 52 (permalink) Old 01-14-2015, 01:14 PM
To Ground, all do eventually and you can't regulate stator output on this system nor most motorcycle engines with a few notable exceptions. Engine rpm dictates stator output. Different style regulators deal with it differently but with a fixed winding in the middle of a rotating permanent magnet, voltage output of the stator is completely at the mercy of RPM. Just the Facts
post #9 of 52 (permalink) Old 01-14-2015, 01:45 PM
Some older Suzuki' s route it back to the stator(2 phase regulator like my gs 650 has)and submerge the stator in the engine oil keep it" cool"
post #10 of 52 (permalink) Old 01-14-2015, 01:49 PM
I as many found the mosfet did a more efficient job of lower rpm power output. Hence, one of the desires to upgrade.
