finally happened - Kawasaki Vulcan 750 Forum : Kawasaki VN750 Forums
post #1 of 8 (permalink) Old 01-03-2015, 10:45 PM Thread Starter
finally happened
Well, looks like I lost the stator.
decided to go ahead and plunge in and do it all right when I do it. Gonna use either a rewind from TPE, or if the local shop my neighbor uses for alternators does stators, may go with them and see how it works out. Also going to go MOSFET regulator, and change them balance dampers while in there...
gathering the parts list of what I need to order so I can get as much ahead of time as possible.
gonna be walking or stealing wifes car for a few while, (possible even a few weeks)
michiganteddybear is offline
post #2 of 8 (permalink) Old 01-09-2015, 05:13 PM
Why change balance dampers?
The constitution was not written for We The People, but rather for those who SERVE THE PEOPLE!
The strongest reason for the people's right to bear arms is as a last resort to prevent tyranny in government,
T Jefferson.....Don't Tread On Me!
grousehunter1475 is offline
post #3 of 8 (permalink) Old 01-09-2015, 05:59 PM
Cause your right in there anyway and you might as well do it now
post #4 of 8 (permalink) Old 01-09-2015, 06:00 PM
Concert connoisseur
wib714's Avatar
because they deteriorate over time and when you change the stator you are only one step away!
how many miles did yours make it? and are you doing the plate mod as well? if you are keeping the bike its a good ideal1
1986 vn 750 aka "Huck Farley"
42,000 miles
Rick's stator and rr
Tuxedo stator cover mod
pickup coil mod
dampers replaced
agm m/f battery
Hid conversion
NGK Iridium spark plugs
wib714 is offline
post #5 of 8 (permalink) Old 01-09-2015, 06:42 PM Thread Starter
a little over 33k showing, but I know my odometer isn't too reliable..
plan on keeping bike, that's why I am going whole hog on it and putting the time/money in now. not sure on the plate yet, will have to see how funds/timing goes. as it is, its gonna be probably 4 weeks before I get it over to the garage where I am gonna do the work
post #6 of 8 (permalink) Old 01-09-2015, 06:43 PM Thread Starter
exactly. 2 bolts away from the dampers, I would be a fool to not change them, especially since my luck (which has run about as true as luck can) I would have to replace them within 6 months.
post #7 of 8 (permalink) Old 01-09-2015, 09:22 PM
I estimate about 40,000 on Melissa Fahye and they just started going.think my stator is done as well.
post #8 of 8 (permalink) Old 01-09-2015, 10:52 PM
Concert connoisseur
wib714's Avatar
I decided on the plate after hearing of a couple failed second stators, and even an installation of a faulty one, 50 - 60 bucks for a plate from glen was worth a little reassurance to me. this is the second time mine has been out. once for a stator and once for an oil leak where I decided to do the dampers while I fixed the leak and do the plate mod
42,000 miles
pickup coil mod
dampers replaced
agm m/f battery
Hid conversion
wib714 is offline
