Need Some Help Identifying Some Connectors - Kawasaki Vulcan 750 Forum : Kawasaki VN750 Forums
post #1 of 17 (permalink) Old 12-10-2014, 01:59 AM Thread Starter
Send a message via Skype™ to B1g_R3d_88
Question Need Some Help Identifying Some Connectors
So I used my newly acquired wiring harness (thanks NDR) and I did have some extra connectors from the dash and a mystery box behind the battery box that didn't plug into the harness. I also have a couple connectors on the harness that had no apparent place to plug into. The bike doesn't even attempt to turn over but I have lights come on on the dash when I turn to the ON position.
This is the mystery box behind the battery box that plugged into the original harness but has no apparent place in the new harness.
This is the connector for said mystery box
This is a single terminal connector that comes out down behind the radiator that I have no idea what it goes to as I never unplugged anything like it from the original harness.
This is a 3 terminal connector that again has no apparent connection as I had not unplugged anything like it from the original. What I forgot to get a better picture of is that yellow wire in the background that has a spade terminal on it. The previous owner had one similar just hanging loosely up under the gas tank not connected to anything.
This is a 6 terminal connector that had a spot in the old harness that doesn't have a spot in the new harness. It is grouped with the left hand switch housing controls (turn signals, horn, high and low beams)
B1g_R3d_88 is offline
post #2 of 17 (permalink) Old 12-10-2014, 01:41 PM
Did your bike by any chance have self cancelling turn signals ? If either bike did the harnesses are different. The ones with the self canceling signals had a time/distance module, for lack of a better name for cancelling the turn signals. The single wire by the radiator looks like the oil sending unit plug or the temperature switch plug for the radiator fan. It's been a while since Imonkeyed with one those harnesses ,so this is just from my memory which isn't to be trusted nearly as much as it used to be. The online service manual in Kanucks sig line may have the schematics in it. There were several different harnesses, Euro models were definitely different and I'm not sure about the Canadian models.
post #3 of 17 (permalink) Old 12-10-2014, 02:57 PM Thread Starter
It is an 86, from what I remember, they did have the self cancelling which would probably explain the bigger connector for the switch housing, I'm getting the new controls from kanuck, so maybe I'll wait and see if that problem fixes itself. Anyone have any idea what the box is behind the battery box, that one had me a little concerned that it is something pretty vital.
post #4 of 17 (permalink) Old 12-10-2014, 03:12 PM
I am guessing here but I would think it is the reserve lighting unit or the time distance module for the signals
post #5 of 17 (permalink) Old 12-10-2014, 03:50 PM Thread Starter
I've got a box that looks really similar on the right side of the battery box that says reserve lighting. My guess is it wouldn't be that, but you never know, previous owner may have replaced it with a new one and just not removed the old one. If it is the time/distance module, there really wouldn't be a need for it with some newer model year controls that don't have that feature though right?I'm thinking I'm going to just have to pull that one to see, thanks for looking though denny!
post #6 of 17 (permalink) Old 12-13-2014, 04:29 PM Thread Starter
Good call Denny, it was pretty tight in there and it had Philips heads on it so I really didn't want to pull off the rear fender or try getting the box out so I just took a rubbing of it. The turn signals work so it looks like they were replaced at some point. Bike still won't even attempt to start though. Bike it's in neutral (yay that works!), tried pulling the clutch in, and the side stand is up, anyone have any clues to get me started?
post #7 of 17 (permalink) Old 12-13-2014, 05:53 PM
does the starter relay click when the starter button is depressed? if no, check for voltage on the small wires on it when the button is depressed. IIf Yes try putting a jumper cable on the positive battery terminal and touch i to the starter terminal on the starter(with the bike in neutral and on the centerstand) , starter should try to turn the engine.
let me know what you find and we'll do some more checking.
post #8 of 17 (permalink) Old 12-18-2014, 10:44 PM Thread Starter
So when I pull the little 2 wire connector out of the starter solenoid and put my multimeter to the 2 wires, I get no voltage whether I'm pushing the starter button or not.
To test the jumping positive battery terminal to negative solenoid terminal, can I use about a 16 gauge wire, or should I use something bigger?
post #9 of 17 (permalink) Old 12-18-2014, 10:56 PM
look in the projects and builds section at my safety switch bypass mod
i am thinking without that one connector hooked up by the tank that comes from the left side controls then it is missing signal from one of the safety switches (clutch switch)
if you do my mod you should be able to get power to the ignition
post #10 of 17 (permalink) Old 12-18-2014, 10:57 PM
here is the link
https://www.vn750.com/forum/showthread.php?t=46010
