Spark Plug Cap Trouble - Kawasaki Vulcan 750 Forum : Kawasaki VN750 Forums
post #1 of 4 (permalink) Old 04-09-2008, 12:35 AM Thread Starter
I WAS WONDERING IF ANYONE HAS EVER ENCOUNTERED SEEING THE SPARK ARC TO THE ENGINE FROM THE SPRK PLUG CAP? I CHECKED THE CAP AND IT DOES NOT APPEAR TO HAVE A HOLE IN IT OR ANYTHING. DOES ANYONE KNOW WHAT THIS COULD BE OR HOW TO FIX IT?
vulcanman is offline
post #2 of 4 (permalink) Old 04-09-2008, 12:36 AM Thread Starter
Thanks For All Your Help.
post #3 of 4 (permalink) Old 04-09-2008, 08:55 AM
stan's Avatar
Is it the right front plug wire? if it is, then it may be arcing on the cable that lays near it. I had that problem on mine...
to fix it I bought a length of fuel line and slit it length-wise, then I placed it over the cable and secured it with zip-ties.
if it is not the right front plug then I guess you will need to change the wire out
best,
Stan
VROC #12293
2004 VN750
MSF Ridercoach
new tires (OEM Stones) 6/2008
home made floorboards (knifemakers styling)
stator replaced 6/2008
cobra slashcuts 7/2007
clear alternatives brake & tailight 8/2008
Added Mutazu hard bags 3/2009
added customLED load equalizers for the bags LED lights 3/2009
stan is offline
post #4 of 4 (permalink) Old 04-09-2008, 09:48 AM
Just because you can't see a hole in the wire doesn't mean there isn't one just big enough to let current through it.
The wires either need replaced or do the fix Stan did until you get new wires.
