What's the problem??? - Kawasaki Vulcan 750 Forum : Kawasaki VN750 Forums
post #1 of 4 (permalink) Old 04-05-2008, 05:08 PM Thread Starter
Vulcan Bobber
aminjuez's Avatar
Question What's the problem??? Battery??? Stator??? R/R???
After 20 or 30 minutes running my bike dies, but before do that she start loosing power in front or rear cylinder, like one of these is switched off, When finally she goes off , so I am trying to start over but the battery is dry.....Today I charge the battery full, start my bike fine,I check the leads, at 4000 or more RPM's the output volts are 13.30 I think is not enough to get the headlight, tails and ignition system (coils) working fine right or not?
so I take out the headlight and tails fuses....now she runs good,(running at 12.61vdc no less) but I need those things working in my bike......What's the PROBLEM? Battery? Stator? R/R?
1989 Vulcan 750
Bobber style.
33000 miles,
aminjuez is offline
post #2 of 4 (permalink) Old 04-05-2008, 05:19 PM
Growling at the World...
bulldog485's Avatar
Send a message via Yahoo to bulldog485
so I take out the headlight and tails fuses....now she runs good, but I need those things working in my bike......What's the PROBLEM? Battery? Stator? R/R?
First thing is to check the battery. That is the most likely problem. It sounds like your battery is not charging. It could be because:
1. Battery is dead and will not accept anything other then a surface charge.
2. Battery connections are not tight. Tighten all your connections to the battery and to the frame. Check every connection.
3. Look at your regulator/rectifier. How does the plug look? Is it in it's original location? Run tests on it with a mulitmeter.
4. Check the yellow wires from the stator to the RR. Are they looking good or are they corroded and or burned up? Look at the wires as they exit the stator compartment. Are they heated up and nasty? Run tests on the stator with a multimeter.
Do you have a short or ground elsewhere in your system that is not allowing your battery to charge? You stated that you remove fuses and the bike runs OK. This could be because you have a shorted leg on your stator and without those extra power drainers, your bike is now getting the voltage it needs or it could be because one of those fuses removed has taken a grounded wire out of the system.
Check it out and give us your findings...
Evan Breyn ~ The Bulldog
http://www.bulldogsbike.com
2006 Harley Davidson Ultra Classic FLHTCUI ~ The Big Black Bitch ~ 26,000 miles.
2002 Kawasaki Nomad 1500 ~ The Red Dog ~ Traded in at 22,000 miles of smiles (purchased new 10/05 / Traded in 6/12).
1990 Kawasaki Vulcan 750 ~ Black Betty ~ 34,999.7 miles
VROC ~v~ 485
McHenry County Road Pirates
Chicagoland, IL
bulldog485 is offline
post #3 of 4 (permalink) Old 04-09-2008, 12:41 PM Thread Starter
Vulcan Bobber
aminjuez's Avatar
Yesterday I was trying to find the problem
I plug the headlight and tail fuses in the function box, whit the multimeter I check continuity, one lead on the headlight fuse the other one on the ground (Bike frame) Result : infinity..... taillight same thing......Is this normal????
1989 Vulcan 750
Bobber style.
33000 miles,
aminjuez is offline
post #4 of 4 (permalink) Old 04-11-2008, 02:50 AM Thread Starter
Vulcan Bobber
aminjuez's Avatar
Unhappy
I think I get it........speedometer light wire (+) was making ground to the frame but I have a suspicion.....Why this not caused a short circuit or a fuse blow? If the positive wire is making contact whit negative wire (ground),bike frame in this case......
1989 Vulcan 750
Bobber style.
33000 miles,
aminjuez is offline
