Stator failure AGAIN! - Kawasaki Vulcan 750 Forum : Kawasaki VN750 Forums
post #1 of 23 (permalink) Old 11-04-2014, 12:39 PM Thread Starter
Okay I did the stator mod I transfer a little bit volts came in at 13. 26. I let the bikes sit for a few days then I tested it again running the bike, and the stator stopped charging. I tested for ground with the stator and the stator is now grounded what the f###! With the bike off my alms are at. [email protected] the ohlm meter is on 200 ohms settin... Some insight as to why my stator failed again would be helpful for the record it is also a brand new regulator rectifier
The constitution was not written for We The People, but rather for those who SERVE THE PEOPLE!
The strongest reason for the people's right to bear arms is as a last resort to prevent tyranny in government,
T Jefferson.....Don't Tread On Me!
grousehunter1475 is offline
post #2 of 23 (permalink) Old 11-04-2014, 12:40 PM Thread Starter
I transfer a little bit is a typo
post #3 of 23 (permalink) Old 11-04-2014, 01:17 PM
What brand stator did you use, and what brand/type of rectifier?
Low oil can cause premature stator failure as well.
post #4 of 23 (permalink) Old 11-04-2014, 02:10 PM Thread Starter
I used low budget brands for both... Oil level was normal
post #5 of 23 (permalink) Old 11-04-2014, 02:21 PM Thread Starter
I should also mention that some smoke came off one of the yellow leads going to the rr not sure if it was the onespliced for the headlight relay or not
post #6 of 23 (permalink) Old 11-04-2014, 02:32 PM
just to double check, oil level normal with bike on center stand?
if its on the side stand, window should be fully covered with oil
michiganteddybear is offline
post #7 of 23 (permalink) Old 11-04-2014, 02:42 PM Thread Starter
Yes bike was on center stand
post #8 of 23 (permalink) Old 11-04-2014, 03:23 PM
if you had one of the yellow wires smoke it means that it was getting to hot due to a bad connection and that will lead to a stator grounding out and becoming faulty
on a side note the cheapest stator I found is the electrosport stator at close to 100 bucks and its a piece of crap however the tim parrot rewound stators are 86 bucks and seem to do fine in our bikes
post #9 of 23 (permalink) Old 11-04-2014, 03:38 PM Thread Starter
I hope that's all it was... I think the stator was an electrosport... The rr is also
post #10 of 23 (permalink) Old 11-04-2014, 04:11 PM Thread Starter
Looks like ill be sending my old Stator in
