repairing cracked signal stalks - Kawasaki Vulcan 750 Forum : Kawasaki VN750 Forums
post #1 of 7 (permalink) Old 10-10-2014, 09:58 AM Thread Starter
Hello,new guy here.I'm in the process of reviving a 1995 vn750.The owner died and his widow wants to see the bike brought back as it has been neglected in a leaky shed for 5 years or so.
Anyway ,as all of you know,I'm sure,the turn signal stalks are all cracked and one snapped in half.Has anyone found some type of glue to fix these or know where you can just get the rubber stalks?I know there are some aftermarket available ,but trying to keep rehab costs to a minimum
I haven't had much luck glueing certain plastics,but then,I have not tried them all.
01fxdxt is offline
post #2 of 7 (permalink) Old 10-10-2014, 11:27 AM
Concert connoisseur
wib714's Avatar
some cheap on ebay that will work. I have used a pin out of a household door hinge pushed through it then wrapped with duct tape for strength then wrapped with electrical tape for appearance. you couldnt tell it was rigged without looking really close!
1986 vn 750 aka "Huck Farley"
42,000 miles
Rick's stator and rr
Tuxedo stator cover mod
pickup coil mod
dampers replaced
agm m/f battery
Hid conversion
NGK Iridium spark plugs
wib714 is offline
post #3 of 7 (permalink) Old 10-10-2014, 11:32 AM Thread Starter
Yea,I should have googled it before posting.Lots of hits on Google.It seems Shoe goo might be worth a try ,but for ten bucks a tube I can get a replcement TS for a bit more,thanks,Ed
01fxdxt is offline
post #4 of 7 (permalink) Old 10-10-2014, 12:08 PM
Yeah honestly replacement ones without rubber stalks are the way to go.
post #5 of 7 (permalink) Old 10-10-2014, 01:40 PM
post #6 of 7 (permalink) Old 10-10-2014, 02:45 PM Thread Starter
Dang,with all the shaving going on here this must be one hairy bike...
01fxdxt is offline
post #7 of 7 (permalink) Old 10-15-2014, 07:55 PM
2000 VN 750 Senior Member
Many have used just a good weather proof glue but put a short piece of a Bic pen barrel inside for added support. This maintains the hollow inside for the wires plus the stiffness to support the previously broken stalk. Do a search here on the forum for some descriptions of "how to".
Tom
Vulcan 2000
4507 miles
Vulcan2000 is offline
