clicking coming from starter relay when trying to start? - Kawasaki Vulcan 750 Forum : Kawasaki VN750 Forums
post #1 of 7 (permalink) Old 10-07-2014, 07:41 PM Thread Starter
Hey all, I searched all day trying to find a thread explaining this but haven't so decided to start one myself. Basically my problem is when I try to turn the bike on the relay just clicks.
It started about a month ago and happened intermittently so I figured replacing the relay would solve it. Wrong; it's only made it worse! Now it won't turn over at all! Just give me that damned clicking! Help please! I've been told it's either the stator or refractor. This is my first bike.
drebin561 is offline
post #2 of 7 (permalink) Old 10-07-2014, 09:53 PM
2000 VN 750 Senior Member
What kind of battery do you have and what is the condition? These bikes need all the juice they can get to start. A gel battery is highly recommended here. Check the voltage and let us know what it shows on a meter. Also check the grounds and cables to the starter.
Tom
Vulcan 2000
4507 miles
Vulcan2000 is offline
post #3 of 7 (permalink) Old 10-07-2014, 10:00 PM
+1...
pay real close attention to the ground connections.. dont take much to kill the starter
post #4 of 7 (permalink) Old 10-07-2014, 11:24 PM
doesn't have to be a gel battery but a good agm maintenance free battery at the least
post #5 of 7 (permalink) Old 10-08-2014, 08:03 AM
rsavant's Avatar
Do you have a volt meter? Start by measuring the voltage on the battery terminals with the bike not running. A fully charged battery should read around 13 to 13.5 volts. Then while monitoring the battery voltage, hit the starter button. If the battery voltage drops substantially, you need a battery. If it stays around 12 volts or so, move next to the solenoid using the same technique. Check the battery side of the solenoid and then the starter side. It's possible you only have a loose or corroded connector.
"Katie"
2002 VN 750, stock except for accessories
Mustang seat
Super Bright LED brake strobe on trunk
About 25k miles
All drive train maintenance performed, drive shaft coupler replaced
Way more experienced at pulling VN 750 carbs than I ever wanted to be.
TOC ACCT rebuild kits installed
Pick up coil mod
Cooling system flushed, refilled with fresh coolant
Petcock rebuilt
VN sold, current steed Honda ST 1300
rsavant is offline
post #6 of 7 (permalink) Old 10-17-2014, 12:52 AM
Alpha Geek
Hexadecimus's Avatar
usually an AGM puts out more amperage than a gel battery on average.
Depends on what you mean by substantially.
Get a free battery load test from autozone etc., a TRUE load test not just a quick voltage test. There's a big difference. If the battery checks out and since the relay clicks, clean/upgrade all of your grounds... then hot wire the starter motor. If it checks out, work your way back to the solenoid, relay, switch, wiring and back to the battery. Should be simple to isolate.
Hexadecimus is offline
post #7 of 7 (permalink) Old 10-17-2014, 01:12 AM
my bike decided to do the same thing the other day and I found that the starter wire had became loose in the eye on the starter I squisheded the holy dog snot out of it with some pliers and blam it starts right up
