anyone is sacramento, ca who can help? - Kawasaki Vulcan 750 Forum : Kawasaki VN750 Forums
post #1 of 6 (permalink) Old 10-05-2014, 09:51 AM Thread Starter
Im havinh starting issues with my 96 vulcan 750. I need someone that has a clue, to diagnose the problem. Thanks, lane. (916) 370-2547.
skinem is offline
post #2 of 6 (permalink) Old 10-06-2014, 09:13 AM
Haven't seen anyone reply here.
Perhaps if you give a detailed discription of the problem we can try and help via this forum.
post #3 of 6 (permalink) Old 10-11-2014, 02:51 AM
Alpha Geek
Hexadecimus's Avatar
Most starting problems I've seen where electrical. Lot of old timers will say "most carburetor problems are electrical" Ignition = air + gas + spark + timing + compression. We can probably assume it's gas or spark.
I assume it cranks. Is it cranking fast enough? If questionable, load test the battery. Good strong spark and proper color?
Check carburetor float levels with some clear tubing to see if either bowl is flooding or not getting enough gas. Draining the bowls and measuring is another way to check, but more prone to errors.
It's hard to help until we hear more.
Hexadecimus is offline
post #4 of 6 (permalink) Old 10-11-2014, 09:11 AM
Mcneuby's Avatar
Starting Problems
What condition I your battery in? You won't belive the difference the proper battry will make. Also the NKG plugs help. Run sea foam in your gas once in a while,
New to me 2004 15k Last liscened in 2011. Stock as they come.
Mcneuby is offline
post #5 of 6 (permalink) Old 10-13-2014, 12:01 AM
If your battery is questionable, disconnect it and try hooking up booster cables from a car battery directly to the mc cables.
post #6 of 6 (permalink) Old 10-13-2014, 09:16 AM
2000 VN 750 Senior Member
Really not sure what is up with this thread or the others started by "skinem". This member seems to start threads and when asked for more information drops away only to start a different thread. Possibly having some other problems taking up his/her time. I know a few responders have asked for some additional information and nothing was posted.
Tom
Vulcan 2000
4507 miles
Vulcan2000 is offline
