WON'T START, NEG TERMINAL WIRE GETS VERY HOT - Kawasaki Vulcan 750 Forum : Kawasaki VN750 Forums
post #1 of 5 (permalink) Old 10-03-2014, 03:29 PM Thread Starter
OKAY,
I HAVE ALL THE SYMPTOMS OF NEEDING TO REPLACE THE STATOR. HOWEVER, I'VE NOTICED WHEN I TRY TO START THE BIKE, THE NEGATIVE BATTERY CABLE GETS VERY HOT. I'VE CHECKED WIRES, REPLACED REGULATOR / RECTIFIER AND CELENOID. BIKE TURNS OVER 2 X'S, ACTS LIKE DEAD BATTERY, AFTER, LOST TAIL LIGHTS, THEN HEADLIGHT.
skinem is offline
post #2 of 5 (permalink) Old 10-03-2014, 04:34 PM
It's a poor connection someplace. Resistance makes wires hot. Check the cable all the way to the starter. That nut can get loss as can the board inside the starter. But seems like if it's hot by the battery the problem is near the battey. take sandpaper to every connection.
post #3 of 5 (permalink) Old 10-03-2014, 04:36 PM
is the cable getting hot in the middle of the cable? or at an end?
if its in the middle, then these are the 2 most common causes.. bad starter (excessive current draw), or bad cable (high resistance, usually due to broken conductors).
if its at a connector, the 2 above, as well as bad connection(s).
Also, check, double check, triple check ALL the ground cables/connections
post #4 of 5 (permalink) Old 10-03-2014, 05:40 PM
Chuck A.'s Avatar
If the stator is bad and the bike hasn't started, why is the headlight? Jumped out maybe?
Chuck A. is offline
post #5 of 5 (permalink) Old 10-03-2014, 06:32 PM
ifixf18s's Avatar
Stator doesn't have anything to do with starting the bike! Unless it's not charging the battery. If the battery is fully charged the stator should not have anything to do with starting.
ifixf18s is offline
