Install spark plugs - Kawasaki Vulcan 750 Forum : Kawasaki VN750 Forums
post #1 of 15 (permalink) Old 03-10-2008, 08:52 AM Thread Starter
Install spark plugs
Hi,
I just bought 4 new spark plugs (DPR7EIX-9). I'm a newbie and I was wondering: is it just a matter of removing the old ones and screw in the new spark plugs?
Willem
gwbosma is offline
post #2 of 15 (permalink) Old 03-10-2008, 09:22 AM
ipfreely's Avatar
Yep, thats pretty much it. Put a little anti-seize compound on the threads before installing them and dont over tighten.
Kuryakyn Flame Grips
Bar End helmet locks
Chrome / Gold "Live to Ride Mirrors"
Coastered, Shaved & Jetted
K&N Pod Air Filters
KisanTech headlamp & Taillight modulators
Iridium's
Leather Lyke Hard Bags
Voltmeter, Clock
Stebel Nautilus horn
Slipstreamer SS28
J&M CB Radio
Audiovox CCS-100 Electronic Cruise Control
Mustang Seat, Protac Drivers Backrest
And of course the obligatory stator replacement[/FONT]
ipfreely is offline
post #3 of 15 (permalink) Old 03-10-2008, 09:55 AM Thread Starter
I'm sorry for the lack of knowledge, but what is anti-seize compound? I've bought the DPR7EIX-9 and didn't take a look at the size. Is this spark plug the same size as the original spark plug? I can still can cancel the order if I've ordered the wrong plugs...
gwbosma is offline
post #4 of 15 (permalink) Old 03-10-2008, 11:03 AM
Vulcaneyez's Avatar
I can't help you with the spark plug question as I am getting ready to do my first plug change and have not checked into what to get yet.
As for the anti-sieze; it is a compound you put on the threads of the plug to keep it from getting stuck. The plug will be easy to remove the next time you do a change. The stuff I have used is copper based, but there may be other materials as well.
Vulcaneyez
Vulcaneyez is offline
post #5 of 15 (permalink) Old 03-10-2008, 11:48 PM
Now what
Ironman's Avatar
Originally Posted by gwbosma View Post
Hi,
Willem
Pretty much. Before you remove the old plugs, blow some air into the chamber around the plug to get any crud out before you pull the old plugs. Use the anti-seize compound (you can get little packs of it at most auto parts stores) on the new threads and start the plugs carefully so you don't cross thread them. DPR7EIX-9 is the right size.
'04 750A- and loving it!
VROC 13864
Using a Purlator One PL14610
Ironman is offline
post #6 of 15 (permalink) Old 03-14-2008, 12:06 PM Thread Starter
What tool do I need to install the plugs? I've read about different sizes. And do I have to adjust the gap or can I install the plugs out of the box?
gwbosma is offline
post #7 of 15 (permalink) Old 03-14-2008, 01:42 PM
Yes, you will need to gap them. And there should be a long spark plug socket in the toolkit that came with the bike.
DougFunnie13 is offline
post #8 of 15 (permalink) Old 03-14-2008, 03:16 PM
85 VN 700
curtis97322's Avatar
It's always wise to check the gap on plugs before installing them. I have the same plugs you ordered and all of them checked out as gapped to specs - but ya never know.
You'll need an 18mm deepwell socket to install the plugs. I use a 3/8 drive craftsman and it works well - though it's a moderately tight fit (most are). As doug said, you might have a long spark plug socket that came with the bike (I and many don't... lost several owners ago I'd imagine).
Curtis - Albany Oregon.
Ammo Can Saddlebags
Hit the 24k mile July 2008
curtis97322 is offline
post #9 of 15 (permalink) Old 03-14-2008, 10:56 PM
I have the same plugs and did not even check the gap! I think you are not supposed to try to gap iridium plugs, they are pregapped.
vylk99 is offline
post #10 of 15 (permalink) Old 03-15-2008, 05:24 PM
Well, I'm a little late in bringing this up, but...
Be sure you have a thin walled socket.
