stator resistance - Kawasaki Vulcan 750 Forum : Kawasaki VN750 Forums
post #1 of 11 (permalink) Old 09-24-2014, 10:11 PM Thread Starter
stator resistance
Can anyone confirm the readings I have for stator resistance (between each stator yellow wire connectors), the manual says between 0.34-0.52 ohms. My meter is on x1 scale as manual says, readings are 4.5 ohms! to me this says stator is faulty but If I put meter scale to x1k the readings are ok! So am I correct with meter setting-see pic.
Mike.
Name:	2014-09-25 10.08.02.jpg
michael2u is offline
post #2 of 11 (permalink) Old 09-25-2014, 04:29 AM
your meter is set correctly
post #3 of 11 (permalink) Old 09-25-2014, 04:55 AM
Originally Posted by michael2u View Post
Can anyone confirm the readings I have for stator resistance (between each stator yellow wire connectors), the manual says between 0.34-0.52 ohms. My meter is on x1 scale as manual says, readings are 4.5 ohms! to me this says stator is faulty but If I put meter scale to x1k the readings are ok! So am I correct with meter setting-see pic. the voltage readings ?
Mike.
I believe your Stator is bad.....what are your voltage readings ? ...initially, that's what counts.....
post #4 of 11 (permalink) Old 09-25-2014, 06:49 AM Thread Starter
hey thanks heaps
post #5 of 11 (permalink) Old 09-25-2014, 05:24 PM
ifixf18s's Avatar
Before you call that stator bad. I would check the voltage at the battery with the RPMS about 3k. Another question I have it what is the ohm reading on your meter when you touch the meter leads together?
ifixf18s is offline
post #6 of 11 (permalink) Old 09-25-2014, 07:16 PM
If you touch the leads of that meter together, Where does the needle land?
in other words, has it been ZERO'd out before taking the reading?
post #7 of 11 (permalink) Old 09-27-2014, 12:43 AM
I would also check to see if the stator is grounded to the engine case. I was getting some conflicting resistance readings, and it was not charging at all. I used a low voltage test light to send power through each of the yellow stator wires, on the stator side. Touching the lead from this light to the case confirmed that voltage was passing through the stator to the case. The stator was completely fried when I removed it. I assume you have a digital meter. I have one too. But I don't like it. I have an old AWS analog meter that I much prefer over the digital one.
2006 Sportster 1200 Low
2004 Honda Rebel 250
1979 Vespa P200E
2002 Vulcan 750 parts bike
1994 Yamaha XT225 parts bike
VN750Rider/Jerry is offline
post #8 of 11 (permalink) Old 10-11-2014, 03:57 AM
Alpha Geek
Hexadecimus's Avatar
I had a stator that grounded out under running load, but not when the bike was shut off, either hot or cold. I pulled it, it tested fine, but it wouldn't make power in the bike. Local alternator shop tested it with high amperage instead of just a multimeter, and he found that the windings were grounding. Just something to consider in your testing. If there's any question, test with higher amperage.
Hexadecimus is offline
post #9 of 11 (permalink) Old 10-13-2014, 05:51 PM
Last year I checked the output, and ohms of my stator and posted here. all values were not as recommended, and the output was; 14 vt @ 1100rpm but but lower at increased rpms. Everyone said my stator was going. Well, that was 18,000 miles ago. Still no problems with battery keeping charged.
smltownr is offline
post #10 of 11 (permalink) Old 10-16-2014, 10:06 PM
Alpha Geek
I think the original R/R has been known to do that sometimes. That's just how it is. I bet you have shunt style like the original, not a MOSFET?
