How often do you change spark plugs - Kawasaki Vulcan 750 Forum : Kawasaki VN750 Forums
post #1 of 15 (permalink) Old 09-21-2014, 09:43 PM Thread Starter
Curious how often most change their spark plugs.
-Robert
RobertGary1 is offline
post #2 of 15 (permalink) Old 09-22-2014, 08:05 AM
If you installed iridiums as suggested here...about every 80,000 miles.
post #3 of 15 (permalink) Old 09-22-2014, 09:34 AM
JM2001's Avatar
21,000 miles on my Iridiums and they look and fire great.
JM2001
" Loud Pipes Risk Rights "
2001 Vulcan 750
marbled
TOC upgrade on ACCT
rectifier relocated
iridiums
decals removed
upgraded mirrors
Pic up coil mod done
degoated
All LED lighting
Upgraded Mosfet rectifier
JM2001 is offline
post #4 of 15 (permalink) Old 09-22-2014, 11:20 AM Thread Starter
What's the p/n on the iridium plugs?
post #5 of 15 (permalink) Old 09-22-2014, 11:41 AM
200% senile
Texas's Avatar
NGK DPR7EIX-9
1996 VN 750
2007 Vulcan Mean Streak SE
When I was younger I was afraid I'd die riding. Now that I'm old and falling apart, I'm afraid I won't.
Texas is offline
post #6 of 15 (permalink) Old 09-22-2014, 01:26 PM
I changed mine every other day it seems like. Eventually I chucked the iridium because they didn't work as well as the plain NGK. The neck on the iridium's on the rear left plug kept breaking for some reason. Maybe I was hitting it with my leg. Very fragile though it that was the case.
post #7 of 15 (permalink) Old 09-22-2014, 01:35 PM
JM2001's Avatar
Have to disagree with everything you said about the Iridiums. Been using NGK plugs for over 20 years in my bikes, boat motors, and lawn equipment with much success. Iridiums are much better than the stock plug. JMO
JM2001
2001 Vulcan 750
marbled
TOC upgrade on ACCT
rectifier relocated
iridiums
decals removed
upgraded mirrors
degoated
All LED lighting
JM2001 is offline
post #8 of 15 (permalink) Old 09-22-2014, 02:00 PM
Ditto that. Never had a problem and they did seem to actually work better. Use them in my car also.
post #9 of 15 (permalink) Old 09-22-2014, 02:11 PM Thread Starter
I've probably got 1,000 miles or so on my NGK coppers. Yesterday I noticed starting was a bit harder than normal and I got some backfire on starting. I pulled the plugs. Generally they look good (no evidence of incorrect mixture or oil). However, they do look well worn. It seems a bit early to wear so much. I sand basted them and was considering putting them back in.
-Robert
post #10 of 15 (permalink) Old 09-22-2014, 03:30 PM
Question: While on subject of Spark Plugs.... If spark plugs get gasoline wet/soaked do to a spark malfunction issue.... malfunction resolved, If cleaned, are they still 100% ?
(Iridiums)
