no lights, no tach??? - Kawasaki Vulcan 750 Forum : Kawasaki VN750 Forums
post #1 of 4 (permalink) Old 02-29-2008, 12:26 AM Thread Starter
Question no lights, no tach???
I was riding home from work today and all of a sudden my headlight , and well lets just say every light on the bike quit working. I got it home checked my battery, it reads 12.8 vdc so that perfect checked my fuses there all good. I am thinking maybe my ignition switch???? Anyone have any ideas???
wicked_speed is offline
post #2 of 4 (permalink) Old 02-29-2008, 09:27 AM
Check your battery leads as well. At the battery and at the bike. I had a loose connection one day & my bike acted very similar. It's possible to be a break in a wire as well. Check by the neck of the bike. I've heard of problems with over extended wires there.
post #3 of 4 (permalink) Old 03-01-2008, 06:00 PM
Sky Rider's Avatar
Could also be the ignition switch, but it's easy to check continuity of the wiring to see if it's a broken wire. Either problem can cause the situation you describe.
Jim W
93 VN 750 "Ursula"
Moved R/R 08Sep06
R/R rewire 17Feb07
New R/R, Installed 14Jun08
New Stator installed 10 Jun08
21480 Miles
VROC #8542
Sky Rider is offline
post #4 of 4 (permalink) Old 03-01-2008, 11:38 PM
Now what
Ironman's Avatar
I'd track down what fuse it should be and swap it out anyway. Small chance that the fuse is shot even though it looks good. (Has happened before and little effort involved) I'd check that all battery cables are good and tight too. A lot of wiring runs through the headlight bucket and things can get chafed in there. I'd pull it and inspect all the wires. A red wire with a blue stripe is the positive for the tachometer and meter lights FYI.
'04 750A- and loving it!
VROC 13864
Using a Purlator One PL14610
Ironman is offline
