stalls on side stand - Kawasaki Vulcan 750 Forum : Kawasaki VN750 Forums
post #1 of 27 (permalink) Old 09-15-2014, 09:37 PM Thread Starter
I have a '96 VN750 and i know its supposed to do this when in gear but this is happening when in neutral, when its on the side stand it stalls 9 times out of 10 unless i have the clutch pulled in, when i let it out it dies or it sits at really low RPMs and acts like it wants to do nothing but stall. Do i just need to clean(or bypass) the kickstand switch? Or is there possibly another problem?
1996 VN750
V&H pipes
HID headlight
Ear shave
Clubman Bars
Matte black plasti-dip "paint" job.
yousername is offline
post #2 of 27 (permalink) Old 09-15-2014, 09:48 PM
Carb issue.....iirc, someone previously had the same issue.
post #3 of 27 (permalink) Old 09-15-2014, 10:01 PM Thread Starter
So would a good few doses of seafoam do the trick or would i need to take it to the shop and have them pulled and cleaned?(i say that cuz i dont have the tools to sync them or the knowledge)
1996 VN750
V&H pipes
HID headlight
Ear shave
Clubman Bars
post #4 of 27 (permalink) Old 09-15-2014, 10:07 PM
Yes, Seafoam is always the best first approach for carb issues.....
post #5 of 27 (permalink) Old 09-16-2014, 06:34 AM
Check how much your tire spins with it on the center stand in neutral. It's ok for it to turn a little, but if you find it hard to stop with your hand, adjust your clutch lever in a quarter turn. Then clean your carbs if needed.
post #6 of 27 (permalink) Old 09-16-2014, 08:02 PM
Not going to recommend it because of all the safetycrats around, but I eliminated both my sidestand and clutch nanny switches. Does it stall while sitting on it in an upright position with the sidestand down? If so does putting the sidestand up stop it? When sitting on the bike in gear with the clutch in, does it want to creep forward?
If moving the sidestand stops the problem, it's that switch. If it tries to move forward in gear with the clutch in, it's the clutch. Mine had warped plates that caused that problem. If it is neither one of these, it could be the carbs, but the fuel level in the carbs should still be high enough while on the centerstand.
I would check everything else before paying someone to remove and clean the carbs. It's likely to be expensive. Synchronizing the carbs is easy. The tool costs less than having someone else do the job, then you have it for next time. Or you could do all the rest of the work and just take it to a shop to get the carbs synced.
But, it is better to track it down methodically, one thing at a time, instead of making guesses and replacing parts. That can get expensive in a hurry.
2006 Sportster 1200 Low
2004 Honda Rebel 250
1979 Vespa P200E
2002 Vulcan 750 parts bike
1994 Yamaha XT225 parts bike
VN750Rider/Jerry is offline
post #7 of 27 (permalink) Old 09-16-2014, 09:31 PM
Sounds to me like a clutch adjustment issue....and maybe a too low idle speed.
Why is your bike running while on the sidestsnd? Are you saying it won't idle sitting still on the stand? And runs fine holding the bike up with the sidestsnd up, in neutral and clutch lever out?
post #8 of 27 (permalink) Old 09-17-2014, 11:20 AM Thread Starter
yes thats what im saying, although even when sitting on it and holding it up it has a bit of an idle problem which i assume is a carb issue which i will be addressing here soon, i just didn't know if it cutting out while leaning on the side stand(in neutral) was the same problem or if it had something to do with the safety switch. But from what i've gathered from everyone is its the carbs.
1996 VN750
V&H pipes
HID headlight
Ear shave
Clubman Bars
post #9 of 27 (permalink) Old 09-17-2014, 04:21 PM
idle should be set to 1100RPM. start there.
If your clutch is not the issue, then you should take one step at a time to troubleshoot it.
Let us know what you find out about the clutch first.
post #10 of 27 (permalink) Old 09-18-2014, 07:10 PM Thread Starter
once she warms up a bit she idles fine while im sitting on her holding her up(clutch out in N), but no matter how warm she gets once i set her on the sidestand she cuts out after a few seconds(clutch out in N). Clutch should be fine, i already got that adjusted when i got my forks redone, put a few oz. of seafoam in the tank yesterday, i'll let the seafoam do its job and see if that helps.
1996 VN750
V&H pipes
HID headlight
Ear shave
Clubman Bars
