Gauges - Kawasaki Vulcan 750 Forum : Kawasaki VN750 Forums
post #1 of 5 (permalink) Old 02-28-2008, 09:13 AM Thread Starter
Gauges
I just recently got my 89 vulcan, and had to order gauges,previous owner removed speedo and tach. So when I got my new ones installed them but I have a slight problem now They sent entire cluster, with 3 pin connectors, a 9 pin a 6pin and a 4 pin however I can't find a 4 pin connector in the bike harness Can anyone help?
Korr is offline
post #2 of 5 (permalink) Old 02-28-2008, 10:01 AM
BMan23777's Avatar
I just went and checked out my 89 Thinking I might be able to help you out.My harness runs from the guages to the headlight housing were they connect to the main harness.But the pin connectors are different I have a 9,5 and 2 set up on mine.If they are not in the headlight housing,have you checked to see if the P.O. pulled them back up under the gas tank or something like that?
Brian Manchester
'89 "GRIMM"
04 durango AWD
BMan23777 is offline
post #3 of 5 (permalink) Old 02-28-2008, 01:04 PM Thread Starter
Not yet,Thanks I'll try that this afternoon
Korr is offline
post #4 of 5 (permalink) Old 02-28-2008, 03:16 PM
Sounds like you got the guages/harness for the earlier bikes; I think the 4 pin is for the speedo lights and distance sensor for the turn signal cancelling setup, if it's coming out of the speedo. The two-pin would be just speedo lights.
Did you order by year model, or by the VIN number?
Jim
J.D.
Kerrville, TX
'95 Vulcan 750 "Therapy II",
aka "Raggedy Ann"
'95 VN750 project
'03 VN800B "The Little Black"
'04 VN800E Drifter project
'93 VN1500A custom project
VROC #16185
GCVROC #33
J.D. is offline
post #5 of 5 (permalink) Old 03-18-2008, 11:30 PM Thread Starter
The shop I bought the bike at got them, I think he got them off E bay
Korr is offline
