Starter Relay - Kawasaki Vulcan 750 Forum : Kawasaki VN750 Forums
post #1 of 9 (permalink) Old 09-10-2014, 08:44 PM Thread Starter
Question Starter Relay
Key on, dash lights up. Push starter button, clicks once, dash lights go out, doesn't start. Attach a jump, turn key on, lights up, tach needle goes up, push starter button and the relay clicks like crazy. Doesnt start. I assume that means my starter relay is bad. Question: what's a good vendor for a starter relay for a 94 VN750?
Jeff is offline
post #2 of 9 (permalink) Old 09-10-2014, 09:01 PM
NEVER TO OLD TO RIDE
V750_outlaw's Avatar
before you go through all that , jump the solonoid and see if it starts
99 vn750A15
stator mod and r/r mod
ignition coil mod
ignitor power circuit and ground circuit mod
ear shave rejet 142/42 plus .040 shimmed
vance and hines exhaust no baffles
custom paint
volt meter
petcock mod
new backrest and pad (no pic yet)
cooling fan cut off switch mod
jbm carb diaphrams (must have)
mcct mod
pickup coil mod
AGM Battery
did all the mods and repair work and custom paint myself. except exhaust.
V750_outlaw is offline
post #3 of 9 (permalink) Old 09-11-2014, 05:19 PM
sounds like a dead battery to me.
if it is the solenoid that is bad, people have used tractor or lawn mower starter solenoids with success. there should be a thread someplace for it.
post #4 of 9 (permalink) Old 09-11-2014, 07:11 PM Thread Starter
It's something. When I first turn the key on, dash and running lights are on. But when I push the start button, it clicks, and all the lights go off. I jumped the solenoid, put the wire from the battery to the wire to the starter, and nothing happens. When I put the jumper to it, the dash and running lights up, the solenoid buzzes, but nothing happens at the starter. The Clymer manual says take the starter off and try putting a different battery to it. The battery says 12.7 volts, or nothing. This sort of thing happened once on my Honda, it was a bad wire in the headlight bucket. It's like 3 things are wrong - the battery, the solenoid, and some sort of gremlin.
Jeff is offline
post #5 of 9 (permalink) Old 09-11-2014, 07:45 PM
first of all, I would hook up one of those car jump start packs to it, or jumper cables directly to a fully charged car battery. Then you know for sure you have enough amperage available. Take the cable clamps, connect the black one to an engine ground, and just touch the red one to the starter. If the starter is good, it will turn over. If it does, then go back to the relay, and touch the clamp to the starter side of the relay. If it turns over, that shows the cable from the relay to the starter is good. Now connect the red clamp to the battery side of the relay, and push the start button. If the starter works, you did not have any current to the relay. If it doesn't, then either the relay is bad, or no voltage is getting to it to trip it. It is possible for a relay to click, and still not transfer enough amperage to a starter to make it work. Also check the ground cables from the battery to the frame, and the frame to the engine. If you are not getting any voltage to the relay to trigger it, then it gets more complicated. The voltage starts out at the battery, then goes through the ignition switch, kill switch, clutch nanny switch, sidestand nanny switch, and probably a few other things before arriving at the relay.
2006 Sportster 1200 Low
2004 Honda Rebel 250
1979 Vespa P200E
2002 Vulcan 750 parts bike
1994 Yamaha XT225 parts bike
VN750Rider/Jerry is offline
post #6 of 9 (permalink) Old 09-11-2014, 08:01 PM Thread Starter
It was a dead battery. Who knew even dead they can register 12.7 volts?
Jeff is offline
post #7 of 9 (permalink) Old 09-11-2014, 08:58 PM
yea, they can. a cell can provide enough juice to read on a voltmeter (microamps of current needed), but as soon as you put a load on it (starter), it opens a cell.
michiganteddybear is offline
post #8 of 9 (permalink) Old 09-12-2014, 05:17 PM
you're welcome! lol
sometimes we over-think things. glad it was simple
post #9 of 9 (permalink) Old 09-12-2014, 05:40 PM
That's called a surface charge. No actual amperage in the battery, just enough of a charge to give a reading.
1979 Vespa P200E
