Head light issues please help - Kawasaki Vulcan 750 Forum : Kawasaki VN750 Forums
post #1 of 8 (permalink) Old 08-29-2014, 02:01 AM Thread Starter
My head light flickers on and off I've checked the fuse and the connections as well. I've cleaned and greased the connections too just running out of ideas anything will help
Cary
Bishopfracer is offline
post #2 of 8 (permalink) Old 08-29-2014, 02:11 AM
did you check all three stator leg connectors? The stator trips the relay witch then in turn lights the headlight.
post #3 of 8 (permalink) Old 08-29-2014, 08:22 AM
Does it do it on both Hi & Low beams?
post #4 of 8 (permalink) Old 08-29-2014, 11:33 AM Thread Starter
Yes it does it on high and low beams
post #5 of 8 (permalink) Old 08-29-2014, 12:35 PM
I ak again are your stator connections clean and tight?
post #6 of 8 (permalink) Old 08-29-2014, 01:17 PM
with no stator you would still have battery power right?
I would put a new fuse in, my truck had a fuse recently that was ok, but once you put a load on it it would act intermittent.
kenny
Merc
2000 Vulcan Drifter 800
Roadhouse classic 2 > 1 exhaust
Okie Smokie intake config
Changed jets
52K miles or so, always going up
Corbin Seat
Painted flat black winter '12
Mercury is offline
post #7 of 8 (permalink) Old 08-29-2014, 03:26 PM
kenny
The stator triggers the headlight relay, so if one or all of the connectors are slightly lose the headlight will flicker on and off
post #8 of 8 (permalink) Old 08-30-2014, 01:43 AM
Understood thanks!
Merc
Changed jets
Corbin Seat
Mercury is offline
