Battery charge go down - Kawasaki Vulcan 750 Forum : Kawasaki VN750 Forums
post #1 of 7 (permalink) Old 02-06-2008, 03:37 AM Thread Starter
Vulcan Bobber
aminjuez's Avatar
Exclamation Battery charge go down
Today I put a new Yuasa Battery full charge (12.5VDC), started the engine and 5 minutes later I verified the volts, for my surprise the volts were falling down little by little so I accelerated to increase charge to the battery but at 3000RPM transmits 12.86VDC at the battery
4000RPM --------- 13.10VDC
1500RPM --------- charge go down.
Somebody Know if this is normal or I get stator or R/R problems, also How many AC volts go out from the 3 yellows wires startor ?
Exists any test for that?......I would be grateful for some help
1989 Vulcan 750
Bobber style.
33000 miles,
aminjuez is offline
post #2 of 7 (permalink) Old 02-06-2008, 05:55 AM
At lower RPM's, the bike is mostly running off the battery, as the stator doesn't really start charging until about 1800+ RPM's.
The voltage from the yellow wires (checking each wire as positive and ground as negative) should be 50+ volts AC.
And .3-.5 ohms checking between each of the stator wires to the others (1-2, 2-3, 3-1)
As long as you are showing increased volts as the RPM's go up, it's probably not the stator. But it should be a little higher at the 4000 range.
Are you sure you have clean and tight connections at the battery?
post #3 of 7 (permalink) Old 02-06-2008, 04:04 PM Thread Starter
Vulcan Bobber
aminjuez's Avatar
connections clean and tight
1989 Vulcan 750
Bobber style.
33000 miles,
aminjuez is offline
post #4 of 7 (permalink) Old 02-06-2008, 08:15 PM
93VN750's Avatar
Also check between each yellow wire and ground, should be infinite. Battery voltage at 4K should be higher, something is amiss.
Jon
vn750.com Member # 828
Rick's Stator and R/R
MF AGM Battery
Degoated
Shaved & Jetted
Iridium's
MAC Tapered Staggered Pipes
Battery/Temp/Clock Gauge
Stainless Steel Brake Lines
Dunlop D-404's
93VN750 is offline
post #5 of 7 (permalink) Old 02-07-2008, 09:50 PM Thread Starter
Vulcan Bobber
aminjuez's Avatar
Thanks fellows, I will check these tomorrow
1989 Vulcan 750
Bobber style.
33000 miles,
aminjuez is offline
post #6 of 7 (permalink) Old 02-08-2008, 10:05 AM
Check your battery ground wire @ the frame--make sure it didn't loosen or that there is no corrosion under the connection
Rckmtn
Dennis Huff
Cheyenne, Wy.
05 VN 750
Spitfire windshield
self canx turnsignals
Jardine 2 into 2
Luggage rack
Extended passenger backrest
KURYAKYN LED voltmeter
130 DB horns
rckmtn is offline
post #7 of 7 (permalink) Old 02-08-2008, 03:38 PM Thread Starter
Vulcan Bobber
aminjuez's Avatar
Good point rckmtn
I will check it
1989 Vulcan 750
Bobber style.
33000 miles,
aminjuez is offline
