Performing stator replacement soon, advice on parts? - Kawasaki Vulcan 750 Forum : Kawasaki VN750 Forums
post #1 of 29 (permalink) Old 08-14-2014, 12:55 PM Thread Starter
Stator is bad (11v at idle and 3.5k RPM, yay!), R/R is probably shot as well (voltage spikes up to 19v while riding), therefore it's time to replace both. I've been reading my ass off all morning on what's needed for the stator replacement process and I'd like to bounce my ideas off all of you wonderful people.
Here's what I'm ordering..
  • TPE Stator
  • FH012AA MOSFET R/R (specced for a Yamaha YZF-R1)
  • Permatex Red & Blue loctite
  • Honda Moly 60 Grease (spline lube while I'm at it)
  • Permatex 22058 Dielectric Grease
  • Permatex 80062 High Tack Gasket sealant
  • 2x James Gasket brand exhaust port gaskets (PN: 17048-98)
Much of my info I've gleaned from various posts here in the forums, and in particular this thread which helpfully listed some part numbers.
I'm shying away from replacing all the gaskets as my budget for this is very tight, the above parts already total out to about $200. How crazy am I for doing that?
Finally.. any advice on things to watch out for? Aside from the thread I linked above, I haven't had much luck finding a good walkthrough with pictures. I'm planning on taking some myself when I do the replacement; this forum has helped me so much thus far I gotta give something back.
kagaku is offline
post #2 of 29 (permalink) Old 08-14-2014, 03:28 PM
Crowley
crowley1027's Avatar
If you haven't downloaded the service manual, you should. It may have a procedure for stator replacement.
crowley1027 is offline
post #3 of 29 (permalink) Old 08-15-2014, 03:03 PM
I don't know if you saw my thread but I just removed my stator two days ago.
All the parts cost me around 140 dollars(although I already had the locktite red and blue and gasket maker om hand).
I'd suggest, replacing the gaskets, there is a very good chance they won't come out in one piece anyway. In my experience with gaskets they almost never come off clean and it's the same principle as when you replace crush washers, gaskets usually only have a one shot run (sometimes you can reuse) but it's just not worth having an oil leak on the part you spent 18 hours replacing.
I ordered all my parts from Ron ayers, they had the cheapest prices and very good service. Cost me 38 dollars for all the parts.
Consult The Repair manual For Parts diagrams, that helped me a lot and includes the part numbers for what you'll have to order.
Sorry I can't offer more, this is only from my experience and I'm definitely not an authority on the matter, good luck!
'04 Vulcan 750 27k+
My first ride- June 2013 @ 22k miles
Stator replaced 27k
"It is the mark of an educated mind to be able to entertain a thought without accepting it." - Aristotle.
"I have never let my schooling interfere with my education"- Mark Twain.
kyledk is offline
post #4 of 29 (permalink) Old 08-15-2014, 03:29 PM Thread Starter
kyledk, are you in the "Fox Valley Area" near Chicago? Also, do you have a list of gaskets / parts you ordered?
kagaku is offline
post #5 of 29 (permalink) Old 08-15-2014, 04:46 PM
I'm in the fox valley area up in Wisconsin, about a 3 hour drive(with good traffic, yah right) north of Chicago.
I used the same parts list as was in the walk through you linked too, however I Also double checked all the parts numbers with the manual. It is in pdf form and I got it from here:https://www.vn750.com/forum/showthrea...ghlight=manual .
It's all kinda vague (doesn't tell you what part is which) but it is a good reference for some things. Just don't fully trust those pictures, as they are grainy with 30 year old technology.
'04 Vulcan 750 27k+
Stator replaced 27k
kyledk is offline
post #6 of 29 (permalink) Old 08-15-2014, 06:34 PM Thread Starter
I took your advice, I ordered all of the gaskets. I found that they had a couple other things cheaper than Amazon too, so got that there as well.
kagaku is offline
post #7 of 29 (permalink) Old 08-15-2014, 09:04 PM
Concert connoisseur
wib714's Avatar
How may miles are on your bike, not a bad idea to replace the balance dampers while you are in there, just a few more bolts and a few more bucks. you might consider the stator cover mod but that would run you an extra 50 or so. I'm in the process of doing that now. had to pull the motor this time for an oil leak
1986 vn 750 aka "Huck Farley"
42,000 miles
Rick's stator and rr
Tuxedo stator cover mod
pickup coil mod
dampers replaced
agm m/f battery
Hid conversion
NGK Iridium spark plugs
wib714 is offline
post #8 of 29 (permalink) Old 08-15-2014, 09:10 PM Thread Starter
26,000 or so. How much are dampers?
'92 Kawasaki Vulcan 750
Mods:
Rattle-can high gloss black paint job
Frame, engine, Headers/exhaust painted satin black
Ears shaved, K&N pod filters
TPE Stator, MOSFET R/R, Magna Power AGM battery
Pickup Coil mod
New mirrors, grips, cables
VN900 seat
Straight pipes with 8" baffles
kagaku is offline
post #9 of 29 (permalink) Old 08-15-2014, 10:36 PM
Ha, my stator went out at 27k, but symptoms were(hindsight) showing at 25k.
Does anyone have any thoughts on if that would be easier or why one would need to remove the bevel vs the rear final drive to disconnect the propeller shaft? after I futs with the bevel case for the good part of an hour I toyed with that idea and heard it mentioned in a post previous to my attempt (I just didn't have the gaskets and so decided to try it next time instead).
Thoughts?
'04 Vulcan 750 27k+
Stator replaced 27k
kyledk is offline
post #10 of 29 (permalink) Old 08-15-2014, 10:39 PM
x2 100% ....will be excellent preventive Maintenance.
I had Stator Mod performed when my balance dampers went [email protected] 13K miles. (over $700.00+ total....don't go there !)
EDIT:4 +2 =6 3 + 2 (5) balance Dampers were $40.00 @ Ron Myers....
Long story....ended up with original Stator ....engine loss Oil Pressure (with charging issues...unk...not thoroughly tested w/Oil pump issues).
...got another engine
