Junction Box Questions??? - Kawasaki Vulcan 750 Forum : Kawasaki VN750 Forums
post #1 of 5 (permalink) Old 01-18-2008, 10:56 PM Thread Starter
Vulcan Bobber
aminjuez's Avatar
Question Junction Box Questions???
Somebody know If it's possible use a junction box of a different kawasaki model??? and also What cause fauld in the junction box???
I did the 4 different inspections like the book say, because the headlight and starter doesn't work and the box no pass(fuses Ok), soo I get replaced.......Please give me a hand
aminjuez is offline
post #2 of 5 (permalink) Old 01-19-2008, 12:43 AM
Search Goddess
Dianna's Avatar
Whenever you want to find out if a part from a VN750 is used on other kawasaki products you go to http://www.ronayers.com/
Look up the part on the on-line microfuche, click on the part number so it comes up with the full part number and price, the paste the part number into the box on the left that says
Where does this part fit?
It then brings up a whole list like this...
Partnumber 59416-1052 , CASE-ELECTRIC,FUSE &, fits 24 models:
Bike Frame
Kawasaki VN750 1994 A10:VULCAN CHASSIS_ELECTRICAL_EQUIPMENT
Kawasaki VN750 1995 A11:VULCAN CHASSIS_ELECTRICAL_EQUIPMENT
Kawasaki VN750 1996 A12:VULCAN CHASSIS_ELECTRICAL_EQUIPMENT
Kawasaki VN750 1997 A13:VULCAN CHASSIS_ELECTRICAL_EQUIPMENT
Kawasaki VN750 1998 A14:VULCAN CHASSIS_ELECTRICAL_EQUIPMENT
Kawasaki VN750 1999 A15:VULCAN CHASSIS_ELECTRICAL_EQUIPMENT
Kawasaki VN750 2000 A16:VULCAN CHASSIS_ELECTRICAL_EQUIPMENT
Kawasaki VN750 2001 A17:VULCAN CHASSIS_ELECTRICAL_EQUIPMENT
Kawasaki VN750 2002 A18:VULCAN CHASSIS_ELECTRICAL_EQUIPMENT
Kawasaki VN750 2003 A19:VULCAN CHASSIS_ELECTRICAL_EQUIPMENT
Kawasaki VN750 1986 A2:VULCAN CHASSIS_ELECTRICAL_EQUIPMENT
Kawasaki VN750 2004 A20:VULCAN 750 CHASSIS_ELECTRICAL_EQUIPMENT
Kawasaki VN750 2005 A21:VULCAN 750 CHASSIS_ELECTRICAL_EQUIPMENT
Kawasaki VN750 1987 A3:VULCAN CHASSIS_ELECTRICAL_EQUIPMENT
Kawasaki VN750 1988 A4:VULCAN CHASSIS_ELECTRICAL_EQUIPMENT
Kawasaki VN750 1989 A5:VULCAN CHASSIS_ELECTRICAL_EQUIPMENT
Kawasaki VN750 1990 A6:VULCAN ELECTRICAL_EQUIPMENT
Kawasaki VN750 1991 A7:VULCAN ELECTRICAL_EQUIPMENT
Kawasaki VN750 1992 A8:VULCAN ELECTRICAL_EQUIPMENT
Kawasaki VN750 1993 A9:VULCAN ELECTRICAL_EQUIPMENT
Kawasaki ZX600 1985 A1:NINJA CHASSIS_ELECTRICAL_EQUIPMENT
Kawasaki ZX600 1986 A2:NINJA CHASSIS_ELECTRICAL_EQUIPMENT
Kawasaki ZX600 1987 A3:NINJA CHASSIS_ELECTRICAL_EQUIPMENT
Kawasaki ZX600 1987 B1:NINJA 600RX CHASSIS_ELECTRICAL_EQUIPMENT
There was a previous thread on the forums just recently where it was mentioned that the Ninja 600 Junction box also fit the VN750 too.
Dianna
Conway, AR
Patriot Guard Rider
2000 VN750 Sere (Serendipity)
1990 GL1500 (Ole Blue)
VROC # 11628 / 25000-H
OKVROC # 18 (H)
TNVROC # 45 (H)
Dianna is offline
post #3 of 5 (permalink) Old 01-19-2008, 12:55 AM Thread Starter
Vulcan Bobber
aminjuez's Avatar
Cool.....thank you Dianna
aminjuez is offline
post #4 of 5 (permalink) Old 01-19-2008, 12:55 AM Thread Starter
Vulcan Bobber
aminjuez's Avatar
aminjuez is offline
post #5 of 5 (permalink) Old 01-19-2008, 01:02 AM
Search Goddess
Dianna's Avatar
Corrosion is usually the main culprit in a junction box being faulty. If the bike had/has a wet cell battery. a battery acid overspill could have seeped in and corroded the relays/diodes inside.
Other times people have noticed a hot spot on the back of the junction box where the back is warped or bubbled from extreme heat (usually caused by a short inside from corrosion.)
Dianna
Conway, AR
Patriot Guard Rider
OKVROC # 18 (H)
TNVROC # 45 (H)
Dianna is offline
