Stator wire question - Kawasaki Vulcan 750 Forum : Kawasaki VN750 Forums
post #1 of 12 (permalink) Old 08-12-2014, 10:39 PM Thread Starter
Mike805's Avatar
So the bike left me stranded today, dead battery. Got stuck having to take the cage into work. Got home, ripped the seat off and tore into it to see what the heck was going on. R/R looked like crap, plug dang near gone from battery acid. So that got cleaned up and relocated. Decided to go ahead and clean all my electric connections while I was at it. Noticed that one of the 3 wires coming from the stator to the r/r was burnt to a crisp. Pulled remaining wires apart just to check and get rid of the connectors and solder them instead. My long winded question is what the heck caused the wire to burn at the connection? Could it have been the 90/100 head light? Bad connection at the r/r? Stumped.
Mike805 is offline
post #2 of 12 (permalink) Old 08-12-2014, 11:02 PM
Chasin' the blacktop
Spencer1's Avatar
An educated guess would lead me to say either just poor wiring from the stator shorting out. At this point I'd be willing to bet your stator is fried.
North Georgia
Spencer1 is offline
post #3 of 12 (permalink) Old 08-12-2014, 11:23 PM Thread Starter
Mike805's Avatar
Joy. Was hoping to get thru the warm months and pull the motor this winter. Need to find a good multimeter and test it all.
Mike805 is offline
post #4 of 12 (permalink) Old 08-12-2014, 11:32 PM
NEVER TO OLD TO RIDE
V750_outlaw's Avatar
was the stator wire that burned up the one that fed the headlamp circuit ? if yes, it may be related to the head light circuit.
99 vn750A15
stator mod and r/r mod
ignition coil mod
ignitor power circuit and ground circuit mod
ear shave rejet 142/42 plus .040 shimmed
vance and hines exhaust no baffles
custom paint
volt meter
petcock mod
new backrest and pad (no pic yet)
cooling fan cut off switch mod
jbm carb diaphrams (must have)
mcct mod
pickup coil mod
AGM Battery
did all the mods and repair work and custom paint myself. except exhaust.
V750_outlaw is offline
post #5 of 12 (permalink) Old 08-13-2014, 02:19 AM
The previous owner of my motorcycle also had an acid leak from the battery. when i bought it it had a closed battery so I never thought to check, but then the stator fried and I'm pretty sure it was because the plug on the RR was half eaten away.
'04 Vulcan 750 27k+
My first ride- June 2013 @ 22k miles
Stator replaced 27k
"It is the mark of an educated mind to be able to entertain a thought without accepting it." - Aristotle.
"I have never let my schooling interfere with my education"- Mark Twain.
kyledk is offline
post #6 of 12 (permalink) Old 08-13-2014, 08:08 AM
JM2001's Avatar
If your charging system is operating at full power you will only have about 40 watts extra to play with. Your 90 watt head light is putting over 35 watts more load on the system than a standard head light, unless it's a HID head light.
JM2001
" Loud Pipes Risk Rights "
2001 Vulcan 750
marbled
TOC upgrade on ACCT
rectifier relocated
iridiums
decals removed
upgraded mirrors
Pic up coil mod done
degoated
All LED lighting
Upgraded Mosfet rectifier
JM2001 is offline
post #7 of 12 (permalink) Old 08-13-2014, 08:42 AM Thread Starter
Mike805's Avatar
Rode her to work this morning. I'm not going to say the problem is fixed, but headlight is brighter, neutral light brighter. Didn't smell electrical when I parked it after 40 miles. Going to get a multimeter from the pump maintenance dept and test it before I leave.
Mike805 is offline
post #8 of 12 (permalink) Old 08-13-2014, 07:10 PM
ifixf18s's Avatar
Didn't see it mentioned, but might want to think about getting rid of that lead acid battery.
ifixf18s is offline
post #9 of 12 (permalink) Old 08-13-2014, 07:53 PM
i think I replaced my stator wires with either 12 or 14ga....I kept em separated, then bound em....if that makes sense....
post #10 of 12 (permalink) Old 08-14-2014, 07:16 PM
Like Jm said....
"90/100 head light"...tick tock...tick tock......
it's just a matter of time now......
