Bike Won't Start! - Kawasaki Vulcan 750 Forum : Kawasaki VN750 Forums
post #1 of 22 (permalink) Old 08-12-2014, 01:46 PM Thread Starter
Angry Bike Won't Start!
Hello, first off thank you to everyone who helps me solve this problem. I will describe the bike, then the issue and everything I know and have checked.
The bike is a 94 and the previous owner had done electrical work on it to make it minimalistic. To start the bike one flips two switches and then presses the ignition button, no key involved.
The problem: I was riding the bike idling at a stop light and it shut off abruptly (no sputtering). When I tried to start it back up the bike made a series of incredibly fast and fairly quiet clicks with absolutely no response from the engine. When I called the previous owner he said I should check the solenoid by removing the two cables from it and tapping them together, when I did this the bike turned over and he concluded that it was the solenoid. Just finished installing the new part and it didn't change a thing. Same exact problem!
What I have tried:
-checked fuses
-checked battery cables for corrosion and tightness
- I tried to jump the bike, and when I did it turned over just fine, but as soon as i removed the jumper cables the clicking ensued when I tried to start it.
Please help! I am completely stumped.
Schweebs is offline
post #2 of 22 (permalink) Old 08-12-2014, 02:04 PM
sounds like a weak battery or charging system or both
michiganteddybear is offline
post #3 of 22 (permalink) Old 08-12-2014, 02:14 PM
emtdon's Avatar
what kind of battery do you have? if it is not a agm take it to orielly or Autozone they will give you 5$ for it. take that and put it toward a new agm battery and a multi meter. once you get the new battery go to this link for further testing info.
https://www.vn750.com/forum/showthread.php?t=24093
Sent from Motorcycle.com App
2003 kaw vn 750 pushing 40,000 miles.
tp stator
dampers
coil relay mod
other stuff not listed
mustang seat
motorcycle repair at a stealership 1 million bucks, repairs with the help of the Vulcan750 forum priceless.
emtdon is offline
post #4 of 22 (permalink) Old 08-12-2014, 07:24 PM
does the rapid clicking noise sound like it is coming from the starter solenoid under the right side cover, or is it more faint and coming from the left side fuse box?
post #5 of 22 (permalink) Old 08-12-2014, 11:36 PM Thread Starter
The clicking definitely sounds like it is coming from the solenoid, it wont start even when it is hooked up to jumper cables so I don't think the battery is the issue. It will turn over when connected to the cables though.
Schweebs is offline
post #6 of 22 (permalink) Old 08-12-2014, 11:56 PM
Chasin' the blacktop
Spencer1's Avatar
starter relay???? but with the clicking coming from the starter probably not,,,,,, just thinking here.
North Georgia
Spencer1 is offline
post #7 of 22 (permalink) Old 08-12-2014, 11:58 PM
NEVER TO OLD TO RIDE
V750_outlaw's Avatar
have you cleaned the battery terminals and connections. maybe a loose or bad contact
the ground most likely
99 vn750A15
stator mod and r/r mod
ignition coil mod
ignitor power circuit and ground circuit mod
ear shave rejet 142/42 plus .040 shimmed
vance and hines exhaust no baffles
custom paint
volt meter
petcock mod
new backrest and pad (no pic yet)
cooling fan cut off switch mod
jbm carb diaphrams (must have)
mcct mod
pickup coil mod
AGM Battery
did all the mods and repair work and custom paint myself. except exhaust.
V750_outlaw is offline
post #8 of 22 (permalink) Old 08-13-2014, 09:11 AM
Start eliminating things. If the bike turns over at all, not a starter problem. You have two switches, on switch turns on the lights I assume and the other is the starter. If the lights come on it's not that switch. The starter switch can cause weird stuff if it doesn't have good contact. Fiddle with that second switch just to make sure. This might explain why by-passing the solenoid makes it turn over but still not start. I agree on cleaning and sanding shiny, every damn electrical connection on the bike.
post #9 of 22 (permalink) Old 08-13-2014, 10:48 AM
Originally Posted by Schweebs View Post
-I tried to jump the bike, and when I did it turned over just fine, but as soon as i removed the jumper cables the clicking ensued when I tried to start it.
This line here is why I think the battery is a problem.
I am assuming you had the cables connected to the battery, and not bypassing any of the electrical systems
post #10 of 22 (permalink) Old 08-13-2014, 11:27 AM
GloryRider's Avatar
X2 on the battery and grounds... make sure you check the engine to frame ground, and sand it down to ensure good contact...
GloryRider
Atlanta, GA
Current Ride: 1995 Vulcan 88 (1500A9)
Purchased Dec. 2014
approx. 6,800 miles
Previous Bike: 2000 VN750 "Glory"
With homemade stator
Details on stator build here
"Four wheels move the body. Two wheels move the soul"
"You live more in 5 minutes on a bike like this going flat out than some people live in their lifetime." - Burt Munro
GloryRider is offline
Tags
battery , electrical , starter
