Can someone school me on the ignition switch? - Kawasaki Vulcan 750 Forum : Kawasaki VN750 Forums
post #1 of 30 (permalink) Old 08-11-2014, 10:27 AM Thread Starter
Crowley
crowley1027's Avatar
I'd like to delete my key ignition with a toggle or toggles. I have it all figured out aesthetically, but not sure mechanically how it will work.
The wiring diagram shows 7 wires going to the switch - two pair and one threesome in the on position.
Can I just wire three toggles? Two two-wire toggles and a tri-wire? Then, to turn the bike on you flip all three.
Sound plausible?
crowley1027 is offline
post #2 of 30 (permalink) Old 08-11-2014, 05:02 PM
Why three toggles... You need one toggle... I will draw it up for you when I get home tonight... Unless I pull another 12 hour shift
post #3 of 30 (permalink) Old 08-12-2014, 09:40 AM Thread Starter
Crowley
Well sir, that's why I asked. I saw three sets of connections made by turning the key on. If I used three toggles, I could control the connections independently?
post #4 of 30 (permalink) Old 08-12-2014, 09:43 AM
I'd like to see this diagram myself. I had often wanted to do this because I had such a problem with that damn switch.
post #5 of 30 (permalink) Old 08-12-2014, 12:33 PM Thread Starter
Crowley
Me too. There seem to be three connections. I'll look at my Clymer in a minute and see what I can come up with
post #6 of 30 (permalink) Old 08-12-2014, 12:52 PM
You have battery hot ak the time, ignition and accessory... So in reality all you need is one toggle to do both
post #7 of 30 (permalink) Old 08-12-2014, 01:06 PM Thread Starter
Crowley
I see orange/green going to the turn signal relay, the white/blue is ground?
Then red to tail light, blue to jb?
Then yellow to stop switch, white ground? And brown/white to r/r or jb.
post #8 of 30 (permalink) Old 08-13-2014, 03:01 AM Thread Starter
Crowley
Nothin'?
post #9 of 30 (permalink) Old 08-13-2014, 09:04 AM
Diagram please!
post #10 of 30 (permalink) Old 08-13-2014, 11:28 AM Thread Starter
Crowley
I have to upload one at a time, for some reason it crashes my app
