Dyna Coils - Kawasaki Vulcan 750 Forum : Kawasaki VN750 Forums
post #1 of 5 (permalink) Old 01-12-2008, 09:45 AM Thread Starter
Scoop's Avatar
Dyna Coils
Anybody using ignition coils from Dynatek? If so which ones?
http://www.dynaonline.com/english/sportbike_coils.htm
I was given a set of DC1-1 coils and was wondering if anyone has tried them and how they work. Thanks.
97 VN 750
R&R Relocated
Degoated
Ears Shaved/Rejetted
MF/AGM Battery
Irridium Plugs
Spring Solo Seat
32 Ford Model A Tail Light
Rear bobbed and hard-tailed!
Scoop is offline
post #2 of 5 (permalink) Old 01-13-2008, 12:45 AM
dirtrack650's Avatar
Give us a report if they do.
I was wanting to put some hi output coils to increase combustion for better fuel milage. I did this back in the 70's on some bikes (Accel car coils - dam ugly but what a difference) and was wondering if it would be worth it with today's technology.
95 VN750 (eBay)31k+
GL1100 front fender
OEM engine guard
OEM high back rest
'V-Twin' HWY pegs
Black 750 Spectre handlebars
SunPro Volt Meter (Amazon)
Maier bug shield (JCW)
Bar Ends anti-vibe (JCW)
Emgo air filters
Tank bag-Eclipse
Tail bag-FroZone Cooler
Back Rest-Igloo 6 pak cooler
WalMart Saddle Bags
Dry Splines Lubed
AGM DieHard-Sears
Gutted Goat
Sporster XL Mufflers
LED's-stop,tail,turn,marker
Pickup coil mod to .45mm
Silverstar headlight
Rotella T6
dirtrack650 is offline
post #3 of 5 (permalink) Old 01-13-2008, 02:25 PM Thread Starter
Scoop's Avatar
Dyna Coils - Install Report
Here's my report -
Got them on today and test rode it a bit. Wow - Big difference!! Very noticable increase in power and smoothness of the engine. Started right up even though it was about 40 degrees out.
I had to modify the coils to get them to mount up in the stock mounting holes. They actually bolted right up but the high voltage outputs were 90 degree off from where they needed to be. So I just drilled the holes 90 degrees and they worked great.
I'll try to post some pics later today.
97 VN 750
R&R Relocated
Degoated
MF/AGM Battery
Irridium Plugs
Spring Solo Seat
Scoop is offline
post #4 of 5 (permalink) Old 01-13-2008, 02:59 PM
Some FYI.....
At the Y! group, there have been reports of the Accel coils being bad news for the bike.
Here's one of those post's....
Originally Posted by Jason Spivy
My rear ignition coil died so I thought I would upgrade to the Accel coils for our bikes. 1 DOA coil, 1 warranty coil which lasted 2 weeks, 2 igniters killed by the coils....
Since forking over for new oem coils, the bike has ran great...
But others have said they've had no problems, so.... who knows??
post #5 of 5 (permalink) Old 01-14-2008, 03:55 PM
About Accel Coils...
I remember needing to use ballast resistors on the + side of the coil wire. Some coils have them built in, some don't need it, but our bikes don't have much room (space) for automotive hi output coils anyway.
SCOOP:
FYI - The bikes that I converted to hi output coils had the same effect that you described. Easy starting, more power, and better fuel economy. CHECK your plugs, you may need to get colder ones to avoid burning holes in your pistons (been there, done that). The big advantage I experienced with my bikes was running up to redline and above (careful). The spark doesn't blow out at high rpm's and the engine will pull harder all the way up.
Yes, pics please.
DT
95 VN750 (eBay)31k+
GL1100 front fender
OEM engine guard
OEM high back rest
'V-Twin' HWY pegs
Emgo air filters
Tank bag-Eclipse
WalMart Saddle Bags
Dry Splines Lubed
AGM DieHard-Sears
Gutted Goat
Rotella T6
