any1 rewired the whole bike???!!!!! - Kawasaki Vulcan 750 Forum : Kawasaki VN750 Forums
post #1 of 32 (permalink) Old 01-09-2008, 09:40 PM Thread Starter
oglejust's Avatar
well my wiring harness is totally trashed so i need to know how to rewire the whole bike. i dont have 2 much bc i dont have turn signals, license plate light, on/off switch, no tach, no speedo, no horns, no temp gauge, and no gas gauge.
i just need to know how to make the engine run the simplest way.
.... slightly modified
oglejust is offline
post #2 of 32 (permalink) Old 01-10-2008, 03:08 AM
Chucklehead
dragon159's Avatar
Well I haven't had to rewire the vulcan but a few bikes ago I had to rewire my old honda due to mice. From experience, the best place to start is getting a good shematic and trace what may be left of the old wires and checking against the diagram. then repair/replace one wire at a time to avoid confusion. Start at the fuse panel and battery and work out. When you start to go crosseyed take a break, then return when sight returns to normal lol. Paperclips and masking tape work good to mark identified wires. Any problems shoot me a line... I'm not too far away from you and one of my strong points as a mechanic is wiring.
dragon159 is offline
post #3 of 32 (permalink) Old 01-10-2008, 06:10 AM
Dianna has a color coded wiring diagram in our gallery, HERE.
post #4 of 32 (permalink) Old 01-10-2008, 07:46 AM
Crobins365's Avatar
Piromedic had to rewire most of his bike about a year ago - not sure if he just got a wiring harness off of eBay or did it all on his own. But you may want to drop him a pm.
C
Crobins365 is offline
post #5 of 32 (permalink) Old 01-10-2008, 08:23 AM
My self, Id vote for a new harness. Rather than physically rewire. It would be just a simpler task, but still alot of work. Good luck!
post #6 of 32 (permalink) Old 01-10-2008, 09:00 AM Thread Starter
oglejust's Avatar
well see the wires that go to the key melted together! and idk y so im wanting to bypass the junction box and ditch the reserve lighting device. i just want the basics... i dont need 5 million wires lol im gonna go thru diannas wiring diagram and take out all the stuff i dont need like turn signals lol
oglejust is offline
post #7 of 32 (permalink) Old 01-10-2008, 09:43 AM
Scoop's Avatar
They sell very basic generic wiring harnesses for custom built choppers. You might try finding one of those. I can't recall where I saw them - and don't have time to do a search right now!
97 VN 750
R&R Relocated
Degoated
Ears Shaved/Rejetted
MF/AGM Battery
Irridium Plugs
Spring Solo Seat
32 Ford Model A Tail Light
Rear bobbed and hard-tailed!
Scoop is offline
post #8 of 32 (permalink) Old 01-10-2008, 11:21 AM
BMan23777's Avatar
You could try Painless performance products.They make all sorts of wiring harnesses for just about anything.
Brian Manchester
'89 "GRIMM"
04 durango AWD
BMan23777 is offline
post #9 of 32 (permalink) Old 01-10-2008, 08:12 PM Thread Starter
oglejust's Avatar
heres a pic of the wiring after i tried to save it
heres what the bike looks like now.... back to square 1
heres the pick of the stock diagram
heres what mine will look like - the reserve lighting device (havent figured out how to bypass it yet)
heres what im gonna start w/ so i can start it
oglejust is offline
post #10 of 32 (permalink) Old 01-10-2008, 08:50 PM
I think ya still need to trim a little off the red wire!!
LOL. Good luck
