temp sender - Kawasaki Vulcan 750 Forum : Kawasaki VN750 Forums
post #1 of 2 (permalink) Old 07-30-2014, 10:12 AM Thread Starter
temp sender
I think my newly bought bike needs a stator I bought a new amg battery. the bike cranked right up,but after running awhile the battery went dead . after reading around on this great site.I have learned how to check the stator .now for this post. I noticed while letting the bike run awhile the temp got hot and i noticed the fan did not come on . Again after reading around on site lfound out that when you unplug the the rad wire and ground to frame fan comes on. question, is there anyway to to keep from buying a 92$ switch.can a cheaper switch be found thanks for any advise .
old gut is offline
post #2 of 2 (permalink) Old 07-30-2014, 10:53 AM
NEVER TO OLD TO RIDE
V750_outlaw's Avatar
You might check with the guys on here that are parting out their bikes, maybe you can buy a whole radiator cheap. They are pretty cheap on ebay also. My switch sticks closed at times so for now I installed an on off toggle switch on the ground wire to the rad switch in the radiator. I shut the switch off after riding. You could do similiar for now but install yours between radiator switch wire and ground to get you going for now.
99 vn750A15
stator mod and r/r mod
ignition coil mod
ignitor power circuit and ground circuit mod
ear shave rejet 142/42 plus .040 shimmed
vance and hines exhaust no baffles
custom paint
volt meter
petcock mod
new backrest and pad (no pic yet)
cooling fan cut off switch mod
jbm carb diaphrams (must have)
mcct mod
pickup coil mod
AGM Battery
did all the mods and repair work and custom paint myself. except exhaust.
V750_outlaw is offline
