is this just mine or what - Kawasaki Vulcan 750 Forum : Kawasaki VN750 Forums
post #1 of 11 (permalink) Old 12-19-2007, 12:42 AM Thread Starter
juggalo62989's Avatar
Thumbs up is this just mine or what
ok so i locked my handlebars to the right when i was at work the other day and when my shift ended i walked out to the parking lot and my bikes tail light was on....... but the key was still in my pocket??? and it ran the battery down... luckily i hill started it but its still really weird. this ever happened to you? or anything else weird like this???
juggalo62989 is offline
post #2 of 11 (permalink) Old 12-19-2007, 01:03 AM
jhuntsman's Avatar
when i first got mine, turning the bars all the way right would set the horn off...played around with the way the wires were ran and haven't had the problem since
jhuntsman is offline
post #3 of 11 (permalink) Old 12-19-2007, 07:13 AM
Is it possible that you locked the bars by turning the key to the right into the "park" position? That will leave the tail light on.
Steve
smadd is offline
post #4 of 11 (permalink) Old 12-19-2007, 06:25 PM
Yeah, what he said.
vn750joe is offline
post #5 of 11 (permalink) Old 12-19-2007, 07:44 PM
Steve
That'd be my guess, so I went out to check my bike, and the tail light doesn't light in park? Flashers and turnsignals work, but no tail light.
Might it have been the brake light?
post #6 of 11 (permalink) Old 12-19-2007, 11:52 PM
Interesting. I've found that my front end will only lock if I turn the bars to the left, not the right. The tire is pointed to the same side as the kickstand. (Or did I misunderstand the reference?) Be that as it may, I've also experienced the thing with the brake lights coming on when it was correctly locked. This happened maybe a dozen times in a row over the course of several days.
The problem simply went away on it's own for me but it's made me LOOK at things before I walk away from it.
Live Long and Prosper is offline
post #7 of 11 (permalink) Old 12-20-2007, 04:32 AM
jhuntsman's Avatar
i was just saying that when the handlebars are completely extended one way or the other, it can mess with the wiring coming from the bars.
post #8 of 11 (permalink) Old 12-20-2007, 10:31 PM
Me too, my bike only locks with handlebars to the left.
But I thought he may be mistakenly turning his key to the right.
vn750joe is offline
post #9 of 11 (permalink) Old 12-21-2007, 04:54 PM
The bike has had wiring harness problems. If the wires are misrouted at the factory hard turns may turn up problems. Mine died on hard rights until the dealer replaced the harness and switch. They stated they had fixed more than a few of 750's with similar problems.
Rckmtn
Dennis Huff
Cheyenne, Wy.
05 VN 750
Spitfire windshield
self canx turnsignals
Jardine 2 into 2
Luggage rack
Extended passenger backrest
KURYAKYN LED voltmeter
130 DB horns
rckmtn is offline
post #10 of 11 (permalink) Old 12-22-2007, 12:26 AM
Chucklehead
dragon159's Avatar
Sounds familliar, mine just popped the fuse for the tail lights when I turned full right, after about an hour of tracing wires I found the harness coming from the keyswitch had rubbed through the plate under the keyswitch and was shorting. I might suggest looking there for a rubbed through wire. I haven't had a problem blowing any fuses since.
dragon159 is offline
