Stator replacement - my experience - Kawasaki Vulcan 750 Forum : Kawasaki VN750 Forums
post #1 of 9 (permalink) Old 07-21-2014, 02:14 PM Thread Starter
Limeybiker's Avatar
Smile Stator replacement - my experience
I just wanted to share this.
I had my original stator rewound by a local company, and obtained a suitable MOSFET R/R.
I followed the engine removal procedure up to the point when the bevel gear was removed. I wanted to get the engine out in one lump, so I left the bevel gear in situ, and removed the final drive instead. This allowed me to disconnect the drive shaft from the engine, and check out my splines at the same time.
When I got the bike back together, I decided to check the output of the windings, before connecting the R/R. At 3000 RPM, I only had 31 V AC. I was expecting to see 40 to 70 V AC, but I continued to connect the R/R. The output from the R/R at 3000 RPM was 13.8 V DC which I am happy with.
The point is that the output of my windings is considerably lower than that in the the charging system check list, but I'm still getting a good output from the R/R.
Discuss.
Just because you're paranoid, it doesn't mean that they are NOT all out to get you.
Limeybiker is offline
post #2 of 9 (permalink) Old 07-21-2014, 02:39 PM
The guy who wound your stator didn't put enough windings in... Secondly any thing under 14 volts while running isn't putting enough back into the battery... Especially when you do a lot of city driving where the fan kicks on a lot
post #3 of 9 (permalink) Old 07-21-2014, 09:56 PM
I agree. When my stock stator was working, I got 50-55 VAC from the stator itself, and 14.5 VDC at the battery terminals, with the engine at 3000 rpm. With what you have, your battery will eventually go dead, even out on the road, especially with the lights on. I rode mine over 300 miles with a dead stator, but I disconnected the headlight, tail light, and fan. When I got home, the battery did not have enough left to start the engine.
2006 Sportster 1200 Low
2004 Honda Rebel 250
1979 Vespa P200E
2002 Vulcan 750 parts bike
1994 Yamaha XT225 parts bike
VN750Rider/Jerry is offline
post #4 of 9 (permalink) Old 07-22-2014, 12:44 PM Thread Starter
Limeybiker's Avatar
Thumbs up
Thanks for your input. (pardon the pun) You're probably right, but I've no intention of pulling the engine again without giving it a chance. Seems strange to me. The people who did the rewind have a very good reputation. They do similar work for Isle of Man TT racers, and motor crossers etc.
Anyway, I'm going to run it and keep an eye on the battery state.
post #5 of 9 (permalink) Old 07-22-2014, 03:41 PM Thread Starter
Limeybiker's Avatar
Thumbs up Battery charging info
I've just been reading some info re battery charging. (Google)
Several articles say that the float charge voltage, i.e. for a fully charged battery is 13.8 volts. This sounds good to me. My battery was fully charged for the test.
Could it be that my new MOSFET R/R is automatically limiting it's output to 13.8 volts? I hope so.
The original VN 750 manual was written 30 years ago, for 30 year old technology.
I now have a new stator and MOSFET R/R. It's not the same.
Only time will tell...........
post #6 of 9 (permalink) Old 07-22-2014, 04:10 PM
I don't totally understand MOSFET technology, but my understanding is that it limits current output, as in amps, not voltage. You should still see 14.XX volts at the battery terminals at around 3000 rpm. You mentioned roadrace and MX bikes. They do not have much electrical output, usually just enough to power the ignition, because they have no lights, horns, fans, electric starters, etc. A street bike needs enough capacity to run all those things and keep the battery charged, even when doing a lot of stop and go riding at low speed.
1979 Vespa P200E
post #7 of 9 (permalink) Old 08-02-2014, 09:31 AM Thread Starter
Limeybiker's Avatar
I've taken the bike out for three or four rides now, and the battery seems to be charging fine. I've also installed a volt meter, which indicates about 14 volts most of the time I'm riding. At idle it's just over 12 volts. I think this is going to be ok.
post #8 of 9 (permalink) Old 08-02-2014, 10:08 PM
My stator did the same thing with around 12v but never got above 13.5 unless at 6k rpm. I replaced the battery and did some tests, thought I fixed it, and got stranded 75 miles between home and the middle of no wear. If you're not sure it will hold at least carry an extra battery of some sort, its worth the hassle imo. *spent 14 hours getting home with only freindly harley riders to help me...soccer moms don't wanna help a 6 foot 6 dude on a motorcycle holding jumper cables*
'04 Vulcan 750 27k+
My first ride- June 2013 @ 22k miles
Stator replaced 27k
"It is the mark of an educated mind to be able to entertain a thought without accepting it." - Aristotle.
"I have never let my schooling interfere with my education"- Mark Twain.
kyledk is offline
post #9 of 9 (permalink) Old 08-03-2014, 01:27 PM Thread Starter
Limeybiker's Avatar
LOL. I'll bear that in mind. Thanks.
I might get away with it. I'm only 5 ft 8.
