Franken-tach - Kawasaki Vulcan 750 Forum : Kawasaki VN750 Forums
post #1 of 7 (permalink) Old 12-06-2007, 01:20 PM Thread Starter
Franken-tach
I just got a used tach off of ebay, and when I received it, it is in worse shape than my current one. The bezel ring is rusted, and there is water inside (the bezel is partially fogged and there are what look like a couple of drips on the face of the gauge.
I see how to get the wiring harness and the bracket off, which is fairly straightforward. Has anyone gone further in dissassembling a tach? I would like to pull the bezel and bezel ring, dry any moisture inside the tach and use the bezel and bezel ring from my current tach, which are in a lot better shape than the new one's, and create my own franken-tach.
Anyone have any suggestions?
--Storm
storm16 is offline
post #2 of 7 (permalink) Old 12-06-2007, 01:53 PM
Crobins365's Avatar
Brad, once you get the housing off the tach, you should see some small screws I think around the outer edge of the white plastic. I may be wrong, but I think those screws hold the unit onto the face plate and stuff. If it isn't those, then check the ones in the center of the back of the unit - those are the ones that had been JB Welded on your old tach so we couldn't pull 'em.
How do the wires look on the "new" unit?
Crobins365 is offline
post #3 of 7 (permalink) Old 12-06-2007, 09:05 PM
Sorry, y'all; if that tach has any little screws around the edge of the white plastic, it ain't like any VN750 tach I've ever seen. I've got one apart in my hand right now.
The bezel is held on by that " or so wide chrome ring at the junction of the housing and bezel. The chrome bezel itself is a cover for another inner metal ring with a gasket around the bottom edge and another wider rubber gasket at the top that holds the lens.
There's 3 ways I know of to get that narrow ring off.
One is to gently pry up the edge on the housing side a little at a time all the way around, then a little more, then a little more, until you get to a point where you can pop it off there. When you put it back together, you gently crimp that edge back down with a pair of channelocks with the jaws taped to keep from messing it up any worse than it already is. Beavis up in Tennessee did it with his.
The second way is to cut the ring. You do _not_ want to do this, unless you're willing to resistance-weld an L-shaped bracket to the cut ends, and bolt it together with a 2-56 or 4-40 bolt, nut, and washers. You'll end up with a gap of about 1/8" to ". The ring I've got here was broken in a wreck; the ends fit together, but not when they're wrapped around the bezel and housing. It ain't going together by hand, that's fer sure.
The third way is to send it to the factory and have them do it; they've got the tool that pops that sucker off and puts it back on in about 3 seconds. There's a dealership in Lincoln, NE, that has that tool, also; and apparently a _very_ few other dealers across the country. (There's actually prolly quite a few that have it, and don't have a flippin' clue what the tool is for.)
Billy Greer's odometer quit on him at ~72,000 miles while on a major trip around the U.S., near Lincoln, as it happens. It was either the Lincoln dealer or the factory that replaced the odometer for him; he told me, but I can't recall for sure which it was. (He did the factory tour thing on that trip)
hth
Jim
J.D.
Kerrville, TX
'95 Vulcan 750 "Therapy II",
aka "Raggedy Ann"
'95 VN750 project
'03 VN800B "The Little Black"
'04 VN800E Drifter project
'93 VN1500A custom project
VROC #16185
GCVROC #33
J.D. is offline
post #4 of 7 (permalink) Old 12-06-2007, 09:47 PM Thread Starter
The wires look pretty good. Everything looks good except the bezel/lens and the ring. I'll try to get this one apart in preparation for Saturday, as well as pulling the tank etc etc.
I've also got to go get the space heater I have lined up...
storm16 is offline
post #5 of 7 (permalink) Old 12-06-2007, 09:51 PM Thread Starter
This sounds like the way to go...Assuming I have the patience to do so.
thanks for the info, Jim.
--Storm
storm16 is offline
post #6 of 7 (permalink) Old 12-07-2007, 08:40 AM
Crobins365's Avatar
hth
Jim
Huh. Well that's not user-friendly! Brad, I'll bring a couple of hammers - we'll get that thing off!
C
post #7 of 7 (permalink) Old 12-15-2007, 11:19 AM
Heheheh...sumpin' tells me that was the whole idea when they designed the thing; tamper-resistant.
Jim
J.D.
Kerrville, TX
aka "Raggedy Ann"
'95 VN750 project
VROC #16185
GCVROC #33
J.D. is offline
