Speedometer doesn't work. - Kawasaki Vulcan 750 Forum : Kawasaki VN750 Forums
post #1 of 6 (permalink) Old 07-14-2014, 01:18 PM Thread Starter
Exclamation Speedometer doesn't work.
My speedometer doesn't seem to work, but I've only been hitting <20mph because the bike is currently in a private community. What's the most comment problem that causes this and what can I do about it?
Best,
Andrey Koltsov
1995 Vulcan 750
Andrey Koltsov is offline
post #2 of 6 (permalink) Old 07-14-2014, 01:32 PM
Deviate's Avatar
The speedometer cable is held in place behind the speedometer with a nut like thing and the same at the front wheel (clutch side of the bike). If you loosen one of those you can pull out the cable and see if it is broken. You can lube it then too if it's not.
I would say a broken cable is probably most common. The speedometer itself could have stripped gears in which case you would need a new speedometer since ours aren't really serviceable. To check that, keep the nut fastened at the wheel and spin the wheel to see if the cable at the speedometer end turns. If it does, chances are it's going to be the speedometer itself.
Leave it to me to NOT be fond of something then end up banging it.
Deviate is offline
post #3 of 6 (permalink) Old 07-17-2014, 12:04 PM Thread Starter
Thank you!
I'll try it out.
post #4 of 6 (permalink) Old 07-17-2014, 12:12 PM
The cable can break inside the jacket, the square end at the speedometer can be stripped too much to engage the gears, or enough to slip and give you wrong readings.
post #5 of 6 (permalink) Old 07-17-2014, 01:08 PM
berzerker1982-BL's Avatar
When mine wouldent work the gears on the wheel were bad....i could spin the wheel and stop the cable
berzerker1982-BL is offline
post #6 of 6 (permalink) Old 07-21-2014, 04:18 PM Thread Starter
Thanks, everyone!
I ended up replacing the wheel with the one from my parts bike and it's all good now.
