charging system - Kawasaki Vulcan 750 Forum : Kawasaki VN750 Forums
post #1 of 5 (permalink) Old 07-06-2014, 09:27 PM Thread Starter
berzerker1982-BL's Avatar
charging system
Ok so just messing around yesterday i checked voltage at batt.
Heres what i got
Engine off. 12.54v
Idle cold 14.35v
4000rpm somewhat cold 14.67
I never did it warm to see if results changed.not sure if that would matter
So does this sound like a healthy charging system?
Is it normal to put out 14+ volts all the time?
berzerker1982-BL is offline
post #2 of 5 (permalink) Old 07-06-2014, 09:37 PM
Heres what i got
Engine off. 12.54v
Idle cold 14.35v
That's great.
wmsonta is offline
post #3 of 5 (permalink) Old 07-06-2014, 09:45 PM Thread Starter
Awsome you think that might mean it has some aftermarket parts on it ?
post #4 of 5 (permalink) Old 07-06-2014, 09:48 PM
I would GUESS so, mine does not perform as well at idle. Dunno.
wmsonta is offline
post #5 of 5 (permalink) Old 07-07-2014, 03:37 AM
Does your R/R look like this?
Or something more like this?
The first is a stock voltage regulator, and the second is a MOFSET R/R upgrade. The numbers you posted in your first post look like those of a MOFSET R/R... also you mentioned you never took hot readings.. those are the most critical readings if you suspect a faulty charging system.
