Need help identifying Mosfet wires - Kawasaki Vulcan 750 Forum : Kawasaki VN750 Forums
post #1 of 6 (permalink) Old 07-06-2014, 07:18 PM Thread Starter
Rylan's Avatar
I picked up this Mosfet and need to identify wires. My goal is to use the stock connections. Already performed the R/R relocate on the original rectifier.
ID:	16986   Click image for larger version
ID:	16994   Click image for larger version
ID:	17002   Click image for larger version
Rylan is offline
post #2 of 6 (permalink) Old 07-06-2014, 08:48 PM
JM2001's Avatar
The grey plug with the 3 wires go to the 3 yellow stator wires. The two wires from the black plug go directly to the battery, hot and ground. The brown wire that went to your old regulator is not needed anymore. Just cap it and tape it.
JM2001
" Loud Pipes Risk Rights "
2001 Vulcan 750
marbled
TOC upgrade on ACCT
rectifier relocated
iridiums
decals removed
upgraded mirrors
Pic up coil mod done
degoated
All LED lighting
Upgraded Mosfet rectifier
JM2001 is offline
post #3 of 6 (permalink) Old 07-07-2014, 11:31 AM Thread Starter
Rylan's Avatar
Ok so the Grey plug on the mosfet (picture with wires connected) those -3 wires each is connected to a yellow wire from the original r/r housing. (the grey plug wire with two plugs connected -- black & white connector, is the same as the other two, plugs assumption the ZX 10 needed the two connectors)
And any two of three black connector plugs on the mosfet direct connect to the battery hot and ground does not matter which plug?
And in the original housing the B/Y wire reserve lighting; B wire ignition on; W wire ignition park-on. all three are not needed when I direct connect the new mosfet to the battery.
Can the B/Y, B, or W, wire connection be used for an accessory later if needed.
Rylan is offline
post #4 of 6 (permalink) Old 07-07-2014, 02:02 PM
I would need to check tonight but I believe it's + on the inside & - on the outside. Center is not used.
post #5 of 6 (permalink) Old 07-11-2014, 12:02 AM
Well, I see nobody's followed up. Your PM was humorous.
Here's a photo to explain it. Pic's worth a thousand words right?
post #6 of 6 (permalink) Old 07-12-2014, 01:56 AM Thread Starter
Rylan's Avatar
Thanks for the pic... I watched the. Roadster factory MOSFET videos very helpful and I got +R and - L. Installed it this evening 20 min and I am now getting 13.9 - 14.0 at idle , 14.2 at 2000 rpm's .... now its a great city bike. Thanks for the assistance.
Rylan is offline
