Front Left Turn signal keeps burning out - Kawasaki Vulcan 750 Forum : Kawasaki VN750 Forums
post #1 of 8 (permalink) Old 06-30-2014, 11:19 AM Thread Starter
What can cause a bulb to keep burning out? I'm on the fourth bulb in two weeks at this point. I've checked the voltages, they seem fine (matching up with the right turn signal and the rears). I also inspected the wiring (although I ran new wires from the wiring harness to the signal itself a few weeks ago), everything checks out.
I would think a fault in the electrical system would cause issues with multiple bulbs, so I'm just not sure where to look.
kagaku is offline
post #2 of 8 (permalink) Old 06-30-2014, 11:21 AM
vibration can cause frequent failures when all else seems to be ok
michiganteddybear is offline
post #3 of 8 (permalink) Old 06-30-2014, 11:27 AM
Loose in the socket can also contribute to failure. Check for side to side and up/down movement.
wmsonta is offline
post #4 of 8 (permalink) Old 06-30-2014, 02:43 PM
Just don't turn left. Not sure if anyone else recommended that but it's worked for me in the past.
post #5 of 8 (permalink) Old 06-30-2014, 09:48 PM
romeobravo172
romeobravo172's Avatar
Sounds like your New Wires might be the culprit!
romeobravo172 is offline
post #6 of 8 (permalink) Old 07-01-2014, 04:09 PM
I hate to say this but....cheap bulbs
A bulb either works or it doesn't....if wiring shorted, the bulb would not burn out because of it(in most cases).
What type of bulb are you using?
for the front use 1157 dual element bulb. Silvania or other popular brands should work fine and last for years.
post #7 of 8 (permalink) Old 07-01-2014, 06:16 PM
they also have some ruggedized bulbs in common auto types. might be worth the extra cost in the end
post #8 of 8 (permalink) Old 07-02-2014, 05:19 PM Thread Starter
The other side just went out.. Very odd, as I redid the wiring months ago and had no issues for well over 700 miles of riding. The bulbs are Sylvania "63" type bulbs. Not sure if these are the stock signals or not. At this point, I've checked out the wiring and can't find any obvious faults. I'm leaning towards just replacing all the signals with some cheap LED ones off eBay in a couple weeks (that and getting some new mirrors). Hopefully that solves my problem.
kagaku is offline
