dim headlight? - Kawasaki Vulcan 750 Forum : Kawasaki VN750 Forums
post #1 of 15 (permalink) Old 11-04-2007, 09:07 PM Thread Starter
oglejust's Avatar
dim headlight?
i noticed lately my headlight on low beam is very dim however on high beam its nice and bright like it used to be. what could be wrong?
.... slightly modified
oglejust is offline
post #2 of 15 (permalink) Old 11-04-2007, 09:32 PM
Have you tried unplugging and replugging the bulb? Your low beam hot side connector may be a little loose or dirty.
post #3 of 15 (permalink) Old 11-04-2007, 09:46 PM Thread Starter
oglejust's Avatar
couldnt mean like a stator problem or a voltage reg. problem could it?
oglejust is offline
post #4 of 15 (permalink) Old 11-04-2007, 09:48 PM
No, not if the high beam is bright.
post #5 of 15 (permalink) Old 11-04-2007, 10:03 PM Thread Starter
oglejust's Avatar
k good
oglejust is offline
post #6 of 15 (permalink) Old 06-19-2011, 07:39 PM
balzout's Avatar
Ive been wondering about this for a while. Had it at the shop and they spent a while trying to track down a short. I already changed the bulb and the shop did too. The shop seems to think there is a short in the stator or a lose connection to the stator.
balzout is offline
post #7 of 15 (permalink) Old 06-19-2011, 09:31 PM
It could be a bad reserve lighting unit or a wire broken from the low beam bact to the rlu.Sounds like the rlu is kicking on.JMO
post #8 of 15 (permalink) Old 06-19-2011, 09:53 PM
This may have nothing to do with your headlight, but according to Daniel Meyer, halogen headlights will burn almost indefinitely.
However they get dimmer with time and should be changed out about every 30k miles on your moto or cage.
http://lifeisaroad.com/stories/2004/...lightLife.html
post #9 of 15 (permalink) Old 06-20-2011, 09:07 AM
Originally Posted by OlHossCanada View Post
This has nothing to do with your headlight, but according to Daniel Meyer, halogen headlights will burn almost indefinitely.
Fixed it for you....
( he said he put in a new bulb)
And I think your limit on Daniel Meyer quotes has run out....
Anyway, be a good idea to check all your wiring...especially the stator wires.
I do need to ask if you just noticed that the headlight seemed dim....as the first time I looked I thought there was something wrong.....only to find out that "that's as bright as it gets" on the stock low beam.
post #10 of 15 (permalink) Old 06-20-2011, 10:37 AM
JM2001's Avatar
Not so. Olglejust posted the problem, then Balzout came in and said he changed his bulb.
JM2001
" Loud Pipes Risk Rights "
2001 Vulcan 750
marbled
TOC upgrade on ACCT
rectifier relocated
iridiums
decals removed
upgraded mirrors
Pic up coil mod done
degoated
All LED lighting
Upgraded Mosfet rectifier
JM2001 is offline
