15.1 volts - Kawasaki Vulcan 750 Forum : Kawasaki VN750 Forums
post #1 of 16 (permalink) Old 06-22-2014, 12:38 PM Thread Starter
darein40's Avatar
15.1 volts
i just replaced the stator and r/r i am getting 12.6 at idle but i get over 15 volts while riding. what would cause the volts to go over 15 volts. and is this a bad thing?
darein40 is offline
post #2 of 16 (permalink) Old 06-22-2014, 12:48 PM
The manual states-14 to 15 volts at 4k rpm's.
wmsonta is offline
post #3 of 16 (permalink) Old 06-22-2014, 12:48 PM
Ndr
15 volts is about the maximum you want to see while above 2-3k RMP. if your reading 15.1V as your max, I THINK that should be OK. this slightly higher reading could be due to a small inaccuracy/error in the voltmeter that you are using. If possible, double check and compare it with a second meter?
Ndr is offline
post #4 of 16 (permalink) Old 06-22-2014, 12:51 PM
Ndr
are you running the stock R/R, or did you swap it for something like the Mosfet R/R
What about the stator? Using a stock/OEM, or did you source one elsewhere?
Ndr is offline
post #5 of 16 (permalink) Old 06-22-2014, 01:29 PM Thread Starter
darein40's Avatar
no running the stock r/r the volts will clime to 15.9 dont know if it will go any higher cause i pull the the clutch so it returns to 12.6
darein40 is offline
post #6 of 16 (permalink) Old 06-22-2014, 02:25 PM
Ndr
I'd say not good. Something is definitely off there. If you haven't already, I'd go through a thorough electrical system test.
here is a link to the thread Slimvulcanrider started awhile back with an attached doc for the testing procedure.
https://www.vn750.com/forum/showthread.php?t=21206
My best guess without seeing any values would be that the R/R is malfunctioning.
Also, is this a stock/OEM stator? Or one made for higher output? I'm wondering: If its a high output stator (such as the rewound ones from Tim Parrot) if the stock R/R can handle it properly.
Ndr is offline
post #7 of 16 (permalink) Old 06-22-2014, 06:24 PM
A high output stator is still limited to the r/r output. So if you out in a TPE stator rated at 50 amps, but still use the stock r/r rated at 30 amps, you will see a high voltage of about 14.6 volts DC
post #8 of 16 (permalink) Old 06-22-2014, 06:33 PM
Ndr
OK, Thanks. That's what I was thinking, just wanted to confirm.
So with him seeing well over 15V DC, my first thought would be that the regulator isn't quite doing its job properly. (of course I could be way off on that) therefore my recommendation to do the full system check to hopefully identify where the issue is at.
Ndr is offline
post #9 of 16 (permalink) Old 06-22-2014, 07:53 PM
High voltage is usually a bad connection at the frame to battery ground... I have a tooth infection so it's hard for me to think
post #10 of 16 (permalink) Old 06-22-2014, 09:40 PM
Ouch.hope you feel better,brother
