Stator replacement question ? - Kawasaki Vulcan 750 Forum : Kawasaki VN750 Forums
post #1 of 8 (permalink) Old 06-21-2014, 04:10 PM Thread Starter
Limeybiker's Avatar
Question Stator replacement question ?
Just a question about removing my old stator. I've removed the housing containing the stator, and I've removed the three hex head bolts which hold the stator to the housing. But the stator seems to be stuck fast to the housing. My instinct is to give it a sharp whack to break it free. I'm just wondering, have I missed something?
Just because you're paranoid, it doesn't mean that they are NOT all out to get you.
Limeybiker is offline
post #2 of 8 (permalink) Old 06-21-2014, 04:24 PM
Yes, this tool.
Motion Pro 08-0116 Flywheel Puller M18X1.5 R.H. External Thread
http://www.amazon.com/dp/B009J7O7J0/...SIN=B009J7O7J0
Tho, NewRider9984 has gotten Stator off without the tool (pry bars & soft hammer)
EDIT: when removing Stator, Be aware, not to lose Key-way key.
Good Luck
post #3 of 8 (permalink) Old 06-21-2014, 06:42 PM
Concert connoisseur
wib714's Avatar
you shouldnt need that to remove the stator from the cover, give me a minute and I'll go look at mine as it is apart for the second time now!
1986 vn 750 aka "Huck Farley"
42,000 miles
Rick's stator and rr
Tuxedo stator cover mod
pickup coil mod
dampers replaced
agm m/f battery
Hid conversion
NGK Iridium spark plugs
wib714 is offline
post #4 of 8 (permalink) Old 06-21-2014, 06:51 PM
Concert connoisseur
wib714's Avatar
yup, those 3 hex bolts should release the stator from the cover, I wouldnt whack it to hard and maybe spray some pb busters on it since you are replacing it anyways. if you are going to have the old one rewound I would tap it in the center and not on the protrusions and bend them
42,000 miles
pickup coil mod
dampers replaced
agm m/f battery
Hid conversion
wib714 is offline
post #5 of 8 (permalink) Old 06-22-2014, 12:04 AM
Chasin' the blacktop
Spencer1's Avatar
Gotta agree with WIB on this one. While William Tech is an honored member and a "Master with the Redheads" (actually WT prefers blue haired punk rock fat chicks with nose rings) I suspect he is thinking about the Rotor which is the magnetized housing which the stator spins inside of. gently pry or tap the stator off the housing (generally they just pull out after removing the 3 bolts). All of this assumes you haven't just pulled the round stator cover off and are instead another layer down and have tilted (or removed) your engine and removed the housing the stator is attached to.
Have a nice day!
North Georgia
Spencer1 is offline
post #6 of 8 (permalink) Old 06-22-2014, 02:25 AM Thread Starter
Limeybiker's Avatar
Thanks. I thought I'd ask before doing something stupid.
post #7 of 8 (permalink) Old 06-22-2014, 12:55 PM
Ndr
Could be "glued" in place by old oil residue...
If your replacing/discarding the old stator, and are VERY careful, I don't see that a few light taps with a rubber mallet should do too much damage.
Just bear in mind that the cover the stator is attached to is cast aluminum and is not very strong to begin with...
Of course, hitting it is last resort if the PB Blaster or other such penetrating fluid would be the best first option.
Ndr is offline
post #8 of 8 (permalink) Old 06-22-2014, 02:55 PM
yup, my bad ....misread the question. Sorry
Have a nice day!
