Wont start - Kawasaki Vulcan 750 Forum : Kawasaki VN750 Forums
post #1 of 17 (permalink) Old 10-24-2007, 12:43 PM Thread Starter
Wont start
I replaced the frame on my 2000 vn750 and now it wont start on me
are there any tricks??
first750ever is offline
post #2 of 17 (permalink) Old 10-24-2007, 12:50 PM
All I can say is just Double Check all your connections. Also be more spacific. Does anything happen? Turn over? Totally Dead?
post #3 of 17 (permalink) Old 10-24-2007, 01:02 PM
if it will crank over and not start and run, check your plugs for gas, wet, dry, condition, if they are completely dry you may not be getting fuel into cyl., if they are wet you may not have spark.. that would be a good place to start. with air , spark and fuel, it should, start and run.
aradams is offline
post #4 of 17 (permalink) Old 10-24-2007, 01:13 PM Thread Starter
The oil and neutral lights are on but when you press 'start' nothing happens
post #5 of 17 (permalink) Old 10-24-2007, 01:17 PM
the "run" switch is on? If so start checking the electrical conections.
post #6 of 17 (permalink) Old 10-24-2007, 01:25 PM Thread Starter
Did all that, There's that sensor on the kick stand looks like its broken
can it cause it not to start?
post #7 of 17 (permalink) Old 10-24-2007, 02:10 PM
stan's Avatar
yes, there is a switch on the kckstand that prevents the motor from running when the kickstand is down....can you bypass it just to see if that is the problem??
VROC #12293
2004 VN750
MSF Ridercoach
new tires (OEM Stones) 6/2008
home made floorboards (knifemakers styling)
stator replaced 6/2008
cobra slashcuts 7/2007
clear alternatives brake & tailight 8/2008
Added Mutazu hard bags 3/2009
added customLED load equalizers for the bags LED lights 3/2009
stan is offline
post #8 of 17 (permalink) Old 10-24-2007, 02:28 PM Thread Starter
How is it possible to bypass it i've tried to disconnect it and connecting both wires together and its still the same...
post #9 of 17 (permalink) Old 10-24-2007, 03:40 PM
The switch on the kickstand prevents you from starting the bike in gear without the clutch lever pulled in. It will also shut off the bike if you put it in gear and try to ride off with the kickstand down. It should have no effect if the bike is in neutral.
And what you did is what he meant by by-passing.
2001 VN750
Vista Cruise Control
V-Force shield
Kawasaki Saddlebag supports
Fixed trunk hinge
TOC MCCT
Clear Alternatives LED tail light
Knifemaker style floorboards
Knifemaker style dash
Avon Venom X 110/90 Front
Avon Venom X 170/80 Rear
Big Crank AGM battery
25,100 miles as of 04/20/2010
lancer19 is offline
post #10 of 17 (permalink) Old 10-24-2007, 05:49 PM Thread Starter
So i guess its something else then...
