Looking for verification - Kawasaki Vulcan 750 Forum : Kawasaki VN750 Forums
post #1 of 3 (permalink) Old 10-22-2007, 05:10 PM Thread Starter
Hey Folks,
'94 with 40k on it. Been having a hard time keeping a charge on the battery and the shop thought it was the battery so it was replaced. The other day I go out and the cooling fan was running though the bike had been sitting for hours and the air temp was cool. I disconnected the fan and went on my ride (200 mile overnight) anyway...not smart, I know
At the furthest point away from home, the battery (new) is dead. Long story short - charged battery - quick run back - battery dead.
Charged the battery, reconnected the fan (spinning and hearing a funny squeak/buzz) but disconnect the cooling fan thermo switch and the fan continues to run and buzzing continues.
Buzzing can be felt at and seems to be from the juction box - remove main fuse - spinning /buzzing stops. Replace fuse - spin/buzz continues.
Remove either set of pin connectors from the junction box - spin/buzz stops -reconnect and buzz/spinning begins again.
Bad junction box?? Anything else I should be checking? I'm kinda new () to this working on a motorcycle so any help would be appreciated.
-Tim
TimC is offline
post #2 of 3 (permalink) Old 10-22-2007, 10:28 PM
Sky Rider's Avatar
Sounds like a stuck relay in the junction box. You can either try and fix it or replace it with a new one. Fixing it may not be practical as it is not designed to be torn apart but there are some here who have done it.
Jim W
93 VN 750 "Ursula"
Moved R/R 08Sep06
R/R rewire 17Feb07
New R/R, Installed 14Jun08
New Stator installed 10 Jun08
21480 Miles
VROC #8542
Sky Rider is offline
post #3 of 3 (permalink) Old 10-23-2007, 10:30 AM Thread Starter
Thanks brother. That was my thought but better to ask than play the expensive game of switching out parts until I find the right one.
-Tim
TimC is offline
