Charging system extra capacity - Kawasaki Vulcan 750 Forum : Kawasaki VN750 Forums
post #1 of 9 (permalink) Old 10-14-2007, 10:43 PM Thread Starter
Drive less, ride more...
theauhawk's Avatar
Did we ever decide how much extra juice (i.e., amps/watts) our bike's charging system has?
I recall seeing an earlier thread where Hizzo seemed to think it was about 70 watts.
Can anyone else vouch for this? Or is his figure a little bit on the aggressive side?
'05 VN750
theauhawk is offline
post #2 of 9 (permalink) Old 10-15-2007, 11:29 PM Thread Starter
theauhawk's Avatar
What???
You mean I asked a question (above) that stumped everybody?
You're kidding!!!....
'05 VN750
post #3 of 9 (permalink) Old 10-16-2007, 12:42 AM
oglejust's Avatar
y what r u wantin to put on it?
.... slightly modified
oglejust is offline
post #4 of 9 (permalink) Old 10-16-2007, 02:17 PM
I thought I remembered Bulldog posting something about what kind of power we have to use, but couldn't find it.
I too thought it was somewhere around 70-75 watts, but I'm not sure if that was extra juice, or total?
post #5 of 9 (permalink) Old 10-16-2007, 03:47 PM
With all the lights on, 70-75 watts couldn't be total output. Add the wattage from all the bulbs with high beams and brake lights on (standard setup. No LED's) and that is (most of) the draw on the system. I was doing some searching and the numbers I keep coming up with is 225-250 watts output total.
2001 VN750
Vista Cruise Control
V-Force shield
Kawasaki Saddlebag supports
Fixed trunk hinge
TOC MCCT
Clear Alternatives LED tail light
Knifemaker style floorboards
Knifemaker style dash
Avon Venom X 110/90 Front
Avon Venom X 170/80 Rear
Big Crank AGM battery
25,100 miles as of 04/20/2010
lancer19 is offline
post #6 of 9 (permalink) Old 10-16-2007, 07:19 PM Thread Starter
theauhawk's Avatar
I will answer my own question.....
OK, for everyone's benefit, I finally took the time to do a real search, and found the following inside the "Vulcan Verses."
Apparently, Electrex is making an upgraded stator (called "Deltaforce") for significantly more juice (but this new amount requires the beefier r/r):
https://www.vn750.com/forum/showthrea...ighlight=watts
'05 VN750
post #7 of 9 (permalink) Old 10-17-2007, 12:05 PM
Simon's Avatar
Was looking up something else and found rthis in the archives - not sure who posted it though. Does this help ?
When the idea of fusing the stator first came up on the main VROC news group, I dug into the manual and found that the specs of the charging system state that the stock stator & regulator/rectifier can generate 24 Amps at 8,000 RPM's. Well, since very few of us would be willing to run our VN750 at that RPM for very long, I suggested we go with 20 Amp fuses because the stator and wire are supposed to handle 24 Amps. This should protect your stator and wire harness from over-current, but it will not protect your stator if the motor gets too hot.
Simon is offline
post #8 of 9 (permalink) Old 10-17-2007, 04:42 PM
70 watts is the amount of available power the bike has with the stock stator. So if you want to add extra lights , you would want to stay under that figure. That is, of course with the bike running at cruising speed and the fan not running.
post #9 of 9 (permalink) Old 10-17-2007, 06:56 PM Thread Starter
theauhawk's Avatar
Thanks for the follow-up, Knifemaker!!!.........
'05 VN750
