Voltage Too High - Kawasaki Vulcan 750 Forum : Kawasaki VN750 Forums
post #1 of 10 (permalink) Old 10-11-2007, 09:17 AM Thread Starter
TechMech's Avatar
Voltage Too High
I'm checking for an electrical problem. Last night, I started the bike and measured the voltage at the battery posts. At idle, I measured the voltage in the 13v -14v range. Moving off of idle, the voltage readings went up. I didn't break 18v, but I did see 17.9+v.
Can this be anything other than the regulator / rectifier?
Assuming I need a new R/R, is it best to go with the Kawasaki OEM R/R, or get one from another supplier? What is best brand - best price?
Second question: Is it still a good idea to put inline fuses on the three yellow wires from the stator? Does it really help protect the stator? If so, what should be the amp rating on the fuses?
Thanks.....
TechMech is offline
post #2 of 10 (permalink) Old 10-11-2007, 10:10 AM
93VN750's Avatar
Thanks.....
It is your r/r. Search the forum on r/r and you'll find plenty of info.
I put the fuses in, but don't think it is going to help much. By the time you blow a 20A fuse, the damage is already done.
Jon
vn750.com Member # 828
Rick's Stator and R/R
MF AGM Battery
Degoated
Shaved & Jetted
Iridium's
MAC Tapered Staggered Pipes
Battery/Temp/Clock Gauge
Stainless Steel Brake Lines
Dunlop D-404's
93VN750 is offline
post #3 of 10 (permalink) Old 10-11-2007, 10:14 AM
Definately sounds like the R/R. Check your stator as well just to be on the safe side.
2001 VN750
Vista Cruise Control
V-Force shield
Kawasaki Saddlebag supports
Fixed trunk hinge
TOC MCCT
Clear Alternatives LED tail light
Knifemaker style floorboards
Knifemaker style dash
Avon Venom X 110/90 Front
Avon Venom X 170/80 Rear
Big Crank AGM battery
25,100 miles as of 04/20/2010
lancer19 is offline
post #4 of 10 (permalink) Old 10-11-2007, 10:25 AM
sunpa's Avatar
First, confirm that your meter is accurate.
- Safety First
Paul
'04 VN750
'75 CB360T
'08 Concours 14
sunpa is offline
post #5 of 10 (permalink) Old 10-11-2007, 10:29 AM
85 VN 700
curtis97322's Avatar
Someone else correct me if I'm wrong - but this does in fact sound like a classic R/R failure. Your stator puts out quite a few volts (70ish AC volts IIRC) and the R/R converts it into DC at a lower voltage. Ricks seems to be the R/R of choice - I'd personally be wary of the RMSTATOR R/R that's been talked about recently because of some likely false claims on there website (which would lead me to expect shoddy/ incomplete build quaility).
The general consensus on the board is that fusing is no longer a good idea.
Ya'll can jump in and disagree with me ;-)
Curtis - Albany Oregon.
Ammo Can Saddlebags
Hit the 24k mile July 2008
curtis97322 is offline
post #6 of 10 (permalink) Old 10-11-2007, 11:22 AM Thread Starter
TechMech's Avatar
"The general consensus on the board is that fusing is no longer a good idea." That's why I think this forum is great: I get the benefit of a lot of people's experiences. It saves a lot of trial and error time....
Thanks......
TechMech is offline
post #7 of 10 (permalink) Old 10-12-2007, 01:39 AM
95VN750's Avatar
Not only no longer fused but still... do not try to dress it up a bit by wrapping the wires up to look neet..... leave them loose as they are other wise they will over heat and burn up.
1980 440LTD
1976 KZ900
1995 VN750 19,500 miles ( start of '08 season ) All mine!
Can't have too many Kaws!
95VN750 is offline
post #8 of 10 (permalink) Old 10-13-2007, 07:29 AM Thread Starter
TechMech's Avatar
I wanted to give an update and some information (which is probably already on the site somewhere.....)
I have placed an order for a Rick's Motorsport Electrics R/R (I hope it is better than the Kawasaki OEM unit....)
I also found the "Diode Testing Procedure - Forward and Reverse Bias Testing" document at www.electrexusa.com. Great document! I never could really deal with the procedures for testing R/R resistance found in the various manuals. What are there, something over 21 different combinations of connections to test?
Anyway, I went through the Diode Testing Procedure and got an indication of one bad diode. I just feel like the problem really is the R/R and yes I do need a new one. If you are trying to diagnose an electrical problem, I highly recommend the Electrex USA Diode Testing Procedure.
TechMech is offline
post #9 of 10 (permalink) Old 10-18-2007, 01:59 PM Thread Starter
TechMech's Avatar
Update:
The Rick's Motorsport Electrics R/R arrived yesterday. I mounted it, started the engine, and measured voltage at the battery terminals. Readings were never above 14.8v. At idle, the readings were in the high 13v range. I consider this problem solved. I am currently happy that I chose a Rick's R/R rather than the OEM unit. I hope I stay that way....
TechMech is offline
post #10 of 10 (permalink) Old 10-18-2007, 03:25 PM
93VN750's Avatar
Update:
I am a EE and have been involved in power supplies for over 20 years. I compared the OEM to the Rick's and there is no comparison. We gutted the OEM unit here in the lab and were very disapointed with the quality of workmanship and thermal design.
I had lengthy talk with Rick before buying their R/R and stator. He knows the vn750 charging system very well and I was confident his parts would work better than OEM version.
Jon
MF AGM Battery
Degoated
Shaved & Jetted
Iridium's
Dunlop D-404's
93VN750 is offline
