Did the Engine Pull to replace the stator and also did the stator mod. - Kawasaki Vulcan 750 Forum : Kawasaki VN750 Forums
post #1 of 12 (permalink) Old 05-27-2014, 10:23 PM Thread Starter
Hello my name is Garrett. I just finished the engine pull to replace my stator and did the mod cutout.Everything seemed to go well .Put all new gaskets on and o rings.Started to put the bike back together and found the shift shaft washer on the floor.Thats the inside washer on the shift shaft at the end before the cover goes on.Need some advice about this washer and its purpose ? I see that there is 4 washers in a row there on the shaft.Can the bike be ran without that last washer on the shaft.I even replaced the oil seal gasket at the end of the shift shaft. If anyone has some advice on this please let me know.I would be greatfull.
Sincerly Sir Garrett
Sir Garrett is offline
post #2 of 12 (permalink) Old 05-27-2014, 11:23 PM
Are you talking about the 13mm "C" clip (mounted up against the engine case - inside the outer Damper/Stator cover), which prevents the shift shaft from moving (abnormally 1" -2") horizontally in & out the engine case ?
post #3 of 12 (permalink) Old 05-28-2014, 01:02 AM
Ndr
I would take the side cover back off and put the washer or snap ring (whichever may be the case) back on properly. The snap ring prevents the shaft from getting pushed into the engine, and the washer prevents the snap ring from binding on the side cover (I think?)
If you're careful, you should be able to wiggle the over off the shaft without damaging the oil seal. Put a little molly grease on the shaft when your putting it back together to let the oil seal slide on nice and smooth.
Ndr is offline
post #4 of 12 (permalink) Old 05-28-2014, 02:25 AM Thread Starter
Oh ok that explains why there are washers on both ends with snap rings in the middle.I wasnt aware that the shifter shaft would move in and out ,because it seems pretty sturdy.So if I leave that one outside washer out,the shaft could move into the engine.That probably wouldnt be to good.Ok thanks for the information it has been helpful.Looks like I will have to pull the engine again and pull the covers to get that washer in place
Thanks Again for the input .
Sir Garrett
post #5 of 12 (permalink) Old 05-28-2014, 09:53 AM
Sir Garrett
....just sayin'.....
A few of us, including myself, have mysteriously lost that "Cir-Clip"....
I added short piece of hose (split lengthwise) over the shaft to hold shift rod out....(snug w/play....not tight) ...rode thousands of miles w/o issues.....a few others have done the same......otherwise, an engine pull to remove the outer (Damper) Cover to replace the $0.50 -13mm Cir-Clip.
post #6 of 12 (permalink) Old 05-28-2014, 10:35 AM Thread Starter
Oh it has been a accidently left out piece by others.Good to know that has happened to others.I think the oil sticks the washer to the back side of the stator cover and when you are pulling the cover you dont see it stuck on the back side of the cover while you are trying to unhook the stator and timing wires that are still connected ,then the small thin washer falls off when you cant see it.Unfortunetly I had 2 big wooden blocks under my bike holding the engine up and it fell between the blocks where it could not be seen.Ok I think I am going to try to add that split hose to the outside of the shift shaft to keep the shaft from moving in or out.That sounds a million times better then pulling the engine again.Thanks for the information update.
Thanks again
Sincerly Garrett
post #7 of 12 (permalink) Old 05-28-2014, 12:35 PM
Might be best to pull the foot lever off and put the hose on without splitting it.
The washer fell off mine the same way, luckily I caught it before putting the cover back.
post #8 of 12 (permalink) Old 05-28-2014, 01:32 PM
Many lose/pop-off the Cir-Clip when replacing the Shift Lever (hammer pressure).
NOTE: !
When replacing the Shift Lever, it would be very wise NOT to exert any kind of heavy pressure on the Shift Shaft inward (I advise NOT TO)......as in DO NOT hammer/pound Shifting Lever on thus placing heavy pressure on your Shift Shaft internals......
.....I advise to split a (HD Fuel) hose.......works ALL day long !
hth
post #9 of 12 (permalink) Old 05-28-2014, 08:32 PM
Shouldn't be using hammers anyway. Two fingers, light pressure, wiggle, ... done.
post #10 of 12 (permalink) Old 05-28-2014, 08:57 PM Thread Starter
Great advise I will keep it all in mind.I will for sure be babying the shifter after getting past that engine pull. Fingers crossed. I will try to give a update on how things turn out.
Thanks all
Sincerly Garrett
