Loose gauges - Kawasaki Vulcan 750 Forum : Kawasaki VN750 Forums
post #1 of 8 (permalink) Old 09-20-2007, 11:47 PM Thread Starter
Finallygot1's Avatar
Loose gauges
Not sure if something is loose or what. My tach and speedo are not even with each other. The speedo seems to be really loose ,jumps around on these "smooth PA roads" . Is there a bushing or something to look for or just take them apart to tighten them up?
Brian
'03 VN750 7,754 as of 10/19
DE-goated,RE-goated,now DE-goated with H-pipe
Willie&Max Saddlebags
Mephis Shades Fats
NGK Iridiums
Cramp-buster throttle
Bulldog R/R relocate
'01 F150 Screw(for the bad weather)
Finallygot1 is offline
post #2 of 8 (permalink) Old 09-20-2007, 11:52 PM
they are rubber mounted inside the chrome besel with 2 10mm nuts. Just had mine apart last week and wasn't able to correct it. I was kinda afraid to over tighten a break stuff.
googy00 is offline
post #3 of 8 (permalink) Old 09-21-2007, 12:10 AM
tlg1's Avatar
Had the same problem with mine a few years back. I disassembled them and found that the rubber mounts had cracked. I then made some new ones out of .50 inch diameter rubber bumpers that were lying around. just took a little trimming for thickness. Haven't had a probem since.
T.G.
Terry
87 VN750 A3
"Trigger"
Black with Silver on tank
Willie & Max saddle bags
Silver Star head lamp
Engine guard
Soft grips
New Stator - Spring 2008
New relocated R/R - Spring 2008
Splines lubed
AGM Deka Battery
tlg1 is offline
post #4 of 8 (permalink) Old 09-21-2007, 12:39 AM
Rider on the Storm
EasyRector's Avatar
My speedo and tach housings were a little loose (cockeyed, vibrating) -- I just tucked the cables under them and that seemed to stabilize them in place, evenly.
EZC
EasyRector is offline
post #5 of 8 (permalink) Old 09-22-2007, 12:40 PM
theres a steel bracket which mounts the clocks via the bushes one could be bent,also my speedo appears a lot looser than my tacho and two days ago my speedo cable unwound itself and dropped off so my advice regularly check the knurled nut at the top of the cable,i know i will be,cheers moose.
moose is offline
post #6 of 8 (permalink) Old 09-22-2007, 01:17 PM
Check the nut at the wheel too. Mine was getting loose at the wheel.
post #7 of 8 (permalink) Old 10-12-2007, 10:26 PM
Loose Gauges
I had this problem with my tach mostly. The problem is the isolation bumper has a ridge that breaks down. I went to my local home depot and bought some rubber washers to "pad" up the space. This worked well. The Speedo doesn't bounce as much as the cable kinda stiffens things up but, it also uses the same mount. You may want to add a large fender type washer on the back under the nut to further limit movement!
Frank.
Frank_G is offline
post #8 of 8 (permalink) Old 10-13-2007, 01:05 PM
Search Goddess
Dianna's Avatar
I got irritated with my tach "bounce" so after looking at how they were mounted, I added a stabilizing bracket between them.
The Tach and Speedo are held off the instrument cluster with a single arm bracket. This gives them the ability to "wave" as you go down the road.
I picked up a brushed aluminum L bracket from Home Depot and drilled two holes, one at each end for the bucket screws to go through
Result is, no more bounce, a stronger support and.. I have a place to mount a clock, blends in nicely too
Dianna
Conway, AR
Patriot Guard Rider
2000 VN750 Sere (Serendipity)
1990 GL1500 (Ole Blue)
VROC # 11628 / 25000-H
OKVROC # 18 (H)
TNVROC # 45 (H)
Dianna is offline
