More head light troubles. - Kawasaki Vulcan 750 Forum : Kawasaki VN750 Forums
post #1 of 16 (permalink) Old 01-17-2005, 05:02 PM Thread Starter
OK here goes.
Recently the headlight failure lamp came on. My low beam is weak, but the high beam seem OK. I replaced the bulb, but the problem is the same. I replaced the Reserve Lighting Unit and the Junction Box, but that did not fix the problem.
Looking at the attachment maybe one of you can help me here.The headlight warning lamp comes on when there is battery on the LG/R wire (#1). The LG/R lead comes from the RLU, but as I said I changed that out, so that isn't the cause.
By progress of elimination I have determined that the BL lead (#2) is causing the LR/R lead to have battery on it.
This lead connects to the Junction Box which I have changed out. So, sometning beyond the Junction Box is causing the trouble.
It looks like that when the Headlight Relay is operated there is 12 volts on the BL lead via the 10 amp fuse which is fed with the BR/W lead #4 which in turn goes to the ignition switch.
I must be reading the diagram wrong, or am I missing something?
I am assuming that the 12 volts on lead #2 is a normal condition, so if there were vo voltage on this lead it might cause a voltage output on lead #1 which would acuse the headlight failure lamp to come on.
Any ideas?
Thanks,
Bob
choppbobby is offline
post #2 of 16 (permalink) Old 01-17-2005, 05:10 PM Thread Starter
Re: More head light troubles.
I could not get the attachment of the wiring diagram to work, so I put it in my web site. http://choppbobby.com/pic.JPG .
The diagram is from the Kawasaki service manual.
Sorry about that.
Bob
post #3 of 16 (permalink) Old 01-17-2005, 08:55 PM Thread Starter
After much tracing wires and taking voltage and coninuity readings I found the trouble by the progress of elimination.
Several years ago I bought a wrecked 1994 VN 750. The front was trashed, but the rest was OK including the electrical parts.
So, I started replacing electrical components,ie. Reserve Lighting Unit, Junction Box, and finally the dimmer switch. That did it. It was the dimmer switch.
It could have been anything I guess, but at least I'm good to go now.
Bob
post #4 of 16 (permalink) Old 01-17-2005, 11:25 PM
Fallguy's Avatar
Glad you got it done man. Since it doesn't look like any of the rest of us was much help...lol
Steve "Fallguy" Fall
Parsons, TN
'04 VN750 "Serenity"
Willie and Max Saddlebags
Ride Bell from Lady Di
Kaw Luggage Rack
Westco MF Batt
Kaw Extended Backrest
http://personalpages.tds.net/~sfall
Pics http://photos.yahoo.com/stevfal
(KIR)
Fallguy is offline
post #5 of 16 (permalink) Old 01-18-2005, 11:44 AM Thread Starter
Thank you.
It was hard to figure out because I could not figure out what caused the Blue lead to go high (12 vvolts). If I han't had the spare parts I'd be still looking.
Bob
post #6 of 16 (permalink) Old 08-12-2005, 02:32 PM
I've got the same problem with the headlight.
I'll try the dimmer switch.
Thanks for the info !!!
Bill
CNI Dawg is offline
post #7 of 16 (permalink) Old 08-12-2005, 02:39 PM Thread Starter
Thanks for the info
You're welcome.
Sometimes electrical problems can be very to fix, but keep at it, and you can do it.
Bob
post #8 of 16 (permalink) Old 08-12-2005, 08:09 PM
ARGH !!!!
I hate electrical problems !!!
Ran the manual's tests on the junction box and the hi/lo headlight switch.
Came up with two bad diodes in the junction box and the headlight switch failed 3 of the 4 tests....ARGH !!!
A stupid headlight switch is over $110 and a junction box is almost $150.
Why in the world would they build the junction box with 4 fuses, 3 relays and 5 diodes in it that is not serviceable????? ARGH !!!
I'm going to remove the headlight/turnsignal/flasher/choke assembly & try cleaning the hi/lo beam switch. Hope the contacts are just dirty (ya right)
Probably can't even get to them to clean the way my luck has been running today.
The only used M/C parts places in town don't have any VN750 parts right now :-(
Probably have to 'bite the bullet' & buy new parts from one of the mail order Kawasaki places. Mean while, the bike is down for repairs till they arrive :-(
Wish I was smart enough to figure out how to bypass all that DOT stuff & wire the headlight direct with fuse, relay, on/off switch, & hi/lo switch.
Heck, they probably have if wired so the bike wouldn't run if you bypass their wiring!
<end rant>
Bill K
CNI Dawg is offline
post #9 of 16 (permalink) Old 08-12-2005, 10:18 PM Thread Starter
If you don't have a kawasaki owner's manual or a Clymer's manual it is inpossible to fix any electrical problem.
Have you ever been to the Yahoo VN 750 group? here is the URL:
http://autos.groups.yahoo.com/groups/VN750 .
Lots of knowledgable folks there to help you.
Also here, http://www.ronayers.com you might find OEM parts less expensive than from Kawasaki.
Also E-Bay has a VN 750 section where you might find parts.
Good luck.
Bob
post #10 of 16 (permalink) Old 08-12-2005, 10:58 PM
It was the dimmer switch!
Bless their little Japanese hearts!They made the left control so you could take it apart.
I disassembled it & found the dimmer switch to be screwed in the housing. I removed it & carefully disassembled it. There are 2 small springs that push the contact plates (2) against the other contact plate that all the dimmer wires are soldered to. All the contacts needed cleaning. I used a little fine sand paper to clean all surfaces. Took the springs out & stretched them a little to increase their tension. applied a thin coat of diaelectric (sp?) grease and reassembled carefully.
IT WORKS FINE NOW ! All the time it was dirty contacts !
Thanks for the tips on the yahoo group (I'm a member there too) and Ron Ayers web site. Ron IS cheaper than the dealer!
I do have the Kawasaki shop manual for this bike. That's where I got the test procedures to check everything.
I have no idea about the diodes in the junction box that didn't test with the ohm meter. But everything works now....I'm happy. I don't have to wait a week for parts & can ride again (at night)
Thanks for your help,
Bill K
CNI Dawg is offline
